Did you get longer studs?
If you read above they werent going to even make the spacers until they had seen that I had replaced my studs. So in answer to the question yes. It cost something like $70 for all the studs to be done by my mechanic.
  • Replies 59
I have 25mm bolt on spacers on my R32 GTR - and this is was my understating is on a couple of the issues you have raised
As far as I know the law in QLD states that it is illegal to alter the overall track (width) of a vehicle by more than 25mm when fitting non-oem wheels. This applies to ALL wheels with or without spacers. Any decent mag wheel shop should be able to tell you this.
So, if the mags you fit do not have the same offset as the original Nissan wheels that came with your car, and the spacers return the overall track to within 25mm of original - they should be fine. I've had a 911 in my past that had spacers fitted in the factory ???
I've also had problems with a steering shudder at around 100kmls - but I swapped my spacers around and the problem went away. I agree, in that it's the spacer that is not balanced (buy better spacers :))
I also know that fitting spacers alters the geometry of the steering – which can put additional stress on the front end - my upper control arms failed almost straight away for example.
I also get quite bad 'tram-lining' on some roads – like the freeway (car seems to follow the ruts in the road). I've been told this is also due to the spacers (SK told me this – so it MUST be true :))
just my 2c worth – all opinion – little fact :)
Well I fitted mine (as pictured in the other post) just earlier today. They fit DAMN snug. They needed a little tap to fit nicely on the hub. They wheels then fitted, not quite so sug to the lip on them. Over all Im quite happy. The car drives very smooth, no problems yet.
One tip with them tho is, do it when the car is cold :( hubs heat up a bit, which means they expand, which means its a bit tricky getting the spacer on.
im actually doing a bit of research for a mate of mine, as my GTR R33 wheels are going on his S14A. out of these opitions, what do u guys think is the best spacer made???
hes trying to get spacers from places like nengun or greenline, would those ones be all right?? or he should get some wheel shop to get them?? cheers
Doesn't really matter where he gets them from, they are all illegal and he will void his insurance for fitting them. They are illegal for a reason I might add.
I'll try to find some for you as requested Frank but just thought I would point out the not so obvious for some people who might not already know.
One tip with them tho is, do it when the car is cold :ninja: hubs heat up a bit, which means they expand, which means its a bit tricky getting the spacer on.
Dave why did you remove them originally?
I still get slight vibrations through the steering wheel after numerous alignments, wondering whether its the 5mm slip on spacers I have and whether something like you had made will help out?
I had crappy slip on ones, they are the rusty ones in the pics I put up on the first page. Hence wanting to change them, to what I have now being the machined ones.
A slight vibration could be also a poor wheel alinement, or even wheel balance. Could well be the spacers too :ninja:
I got mine as they are safter than the typical slip on type most people have. They are still a bit of a bandaid, but a very good one.
i was told by someone today my rims do fit on a S14 without spacers, great news......
rolling the guards is not illegal, is it??? lol....
Everything is illegal, just depends on the cop that pulls you over. :)
Who has spacers? - me
What size are they? - 20mm
Floaters or actual bolt in ones? - bolt on
What car is it on? - r33 s2
What is the law in QLD? - take a guess
i would recommend getting 25mm at least (easy to fit). on mine i had to take about 5mm off of each stud, all 20 of them :) that was exciting.
as per handling and high speed stability they are great (not sure about some ppl say their car shakes and stuff - do proper wheel alignment!)
the only thing now is my wheels + spacers make an offset of +25 so i can't lower the car as much as some ppl do without rolling the guards, but im happy with the way it is now :D
included a few pic of them on (also have photos of car before and after, pm me if interested)
Edited by WhitePrincess
I'm keen on a pair of 8mm lightweight jap made ones if anyone can help.. One of my front 5mm is cracked... keen to replace it and at the same time delete the need to run two spacers each side.
Ok didnt feel the need to read the whole thread but read enough to get the idea.
My parents own a tyre store here in Townsville which i used to work at. The law states that a spacer to be legal MUST be fixed to either the hub or back of the wheel. So slip on spacer ARE illegal. As far as wether spacers cause shakes or not, yes 99% of them do. but sometimes it is fixableish, but takes alot of time and a shit load of mucking around, and balancing the whell 300 times is not going to fix it. The reason being is that they (spacers) make the whole assembly (of tyre and wheel) out of round, if you jack up one corner of the car and spin the wheel you will get a high spot, this IS what causes the shake 99% of the time. But please also note that poor quality wheels that require hub rings to take up the the area where the centre hole in the wheels is not a snug fit will do exactly the same thing, and believe it or not so do poor quality tyres. Trust me i used to fix these problems every day of the week. Also there is a miss conception the wheel alignment fixes shaking problems....WRONG. A wheel alighment is there to adjust your cars wheel geometry ie caster, camber, toe, SAI etc hence the name wheel ALIGNMENT not wheel BALANCE!
Cheers Daniel
Edited by SLO-89
White Princess
they look hot. how much did they set you back? did you get all 4 or just 2??
i was looking around everywhere for spacers, prices vary a lot :D the best price i could find was here -> http://www.justjap.com/parts_nhubs.htm - got 4 of them
    • Shove more foam in it as a minimum if you possibly can. Or steel wool (not the stuff with soap on it!) Baffles / getting the oil out of the air is huge, and should be done at both the cam cover, and the catch can.   I'm about to do a power steering reservoir, and even that needs some thought to make sure air is separated from the oil, to stop evil Cavitation. I'll probably look at doing my own catchcan later on too.
    • I was once told, who it was I'm to old to remember, that the length of the OEM wheels brace supplied with a vehicle is designed long enough for a average person to apply enough torque to do up, and undo the wheel nuts to the specified torque  What a average person is is anyone's guess though, i.e. average fat bastard, average knuckle head, average perfect sized human......like me Unless of course, a tyre shop has ugga dugga'd them up to "torque to yeild/strip" specs, used cross threading as natures lock tight, or a big breaker bar was used to tighten them up to get some nice stretch in the poor old wheel studs Me, I torque wheel nuts to 1 elbow joint click, lower torque settings are based of wrist clicks, higher torque settings are based of shoulder clunks, or total dislocation for anything that requires all of the torques
    • I think the catch can design is pretty flawed. Evident in the fact that the V2 one moved to a larger top mounted filter which alone would have helped with overflow and reduce restrictions compared with the side filter. I also imagine there was a major improvement to the baffling design. It is worth mentioning that this catch can with the RB20 was never as much of an issue and the high kms RB25 is likely a part of the problem. I have gotten quotes for both a new "Vibrant Gen 3" catch can and to modify this existing ones but that may have to wait until after the track day. I hope the sump/head breathers/drains and cam splash plates will be enough
    • Yep, both. The ratio is 1.8 instead of OEM being 1.7. The rocker bodies are modified with a larger bolt hole and re-threaded with 10mm holes instead of the 8mm YT has stock. Finding out they don't actually fit the stock castings cause a lot of un-impressment by the person in the USA who tapped the new holes for the 'upgraded' YT product. He was very unhappy with them given their previous design did not require 'clearancing'
    • That too, but I think this is why she's put the work into the cam cover baffles. I mean, a catch can should only need to be a catch can, not an oil air separator also. Not to say that putting the effort into having it do a better job of oil-air sep is a waste of time, but doing the sep earlier is always going to make life better. And that should happen now anyway.
