Hi everyone (most notably SK).
Just wondering if anyone has done a 4 corner balance (as in weighed car on 4 scales) after installing height adjustable dampers?
And if so what were the results?
I ask this as I am about to install a set of Tein Flex Dampers and had read somewhere that to be totally accurate and for drivability this is the method best employed.
cheers
Muz
https://www.sau.com.au/forums/topic/131192-balancing-car/
yes i've done it. i dont quite know what you mean by 'what were the results'... well the result was the cross weights were set correctly, and the suspension heights set accordingly. if you want the corner weights set then just take it to a suspension place and have them set it up for you. easy. :wave:
https://www.sau.com.au/forums/topic/131192-balancing-car/#findComment-2428056
yes i've done it. i dont quite know what you mean by 'what were the results'... well the result was the cross weights were set correctly, and the suspension heights set accordingly. if you want the corner weights set then just take it to a suspension place and have them set it up for you. easy. :O
Sorry BB, I should have been more specific. Did you do any before and after comparisons. Like , was there any noticable effect on the handling, braking, driveability of the car?
Cheers
Muz
https://www.sau.com.au/forums/topic/131192-balancing-car/#findComment-2429581
Cheers
Muz
What we are doing by corner weighting a car is making sure that it puts its weight down evenly, the two front tyres carry the same load and the two rear tyres carry the same load. The total diagonal weights are even.
For an un-corner weighted car, think of a rocking table, with 1 leg shorter than the other 3. When you lean on one corner (turn left round a bend), the table (car) goes bonk until that short leg hits the floor (the spring takes the load). Now lean on the other end (turn right around a corner), the table (car) goes bonk until that leg hits the floor (the spring takes the load).
So when you have 2 corners, one after the other, you get instability (bonk) whenever you turn the steering wheel. This makes the driver feel like the car is slipping just as he turns the steering wheel, he has no confidence. It also unsettles the car, the tyres don't like the sudden hit of load (bonk) and they do actually slip a little.
How much difference does it make? It's like a dyno tune, if the weights are out by a lot, then it makes a lot of difference. If they only out by a little bit, it makes very little difference.
:P cheers ;)
https://www.sau.com.au/forums/topic/131192-balancing-car/#findComment-2429848
Thanks SK (legend). I kind of thought it would be that or something very similar to what you have described. I will definitely be having this done when the Tein's are installed. Just one more question (sorry), does a drivers weight impact upon this setup or is it a case of only diagonal weights being critical and not same side?
cheers
Muz
https://www.sau.com.au/forums/topic/131192-balancing-car/#findComment-2430081
Yes the driver should be sitting in the car with the expected fuel load when you do the weighing.
But is this for road or circuit use? because on the road you have passengers, very different fuel loads, stuff in the boot etc etc
https://www.sau.com.au/forums/topic/131192-balancing-car/#findComment-2430102
Yeah I had it done on my toymotor. Results were amazing. I installed it myself at first and it was very weird. Spring pre-loadings were also tampered with before I opened the box so that certainly didn't help. Afterwards the car was much more composed.
https://www.sau.com.au/forums/topic/131192-balancing-car/#findComment-2430434
Yes! it presents a conumdrum doesn't it. I was specifically talking about road use.
cheers
if you are talking about road use then it may be a waste of time. just set the heights as accurately as you can.
https://www.sau.com.au/forums/topic/131192-balancing-car/#findComment-2431150
1. So what about cars with non adjustable height? Nothing much can be done eh?
2. And what about FWDs?
3. Would their ass be on the ground and nose up in the air?
1. Use spacers
2. No difference to RWD or 4WD. Many front wheel drive cars have better front to rear weight distribution than a Skyline with that great lump of RB cast iron in front of the front wheels.
3. No, the front left should carry the same weight as the front right and the rear left should carry the same weight as the rear right. More precisely the diagonals should weigh the same.
:/ cheers :/
https://www.sau.com.au/forums/topic/131192-balancing-car/#findComment-2432488
  • 1 year later...
What is the best front to rear weight distribution has anyone achieved for the skyline?
Mine was like 900kg (60%) front and 600kg (40%) rear.
From memory the R32GTST was around 650 (55%) and 550 (45%)
Cheers
Gary
https://www.sau.com.au/forums/topic/131192-balancing-car/#findComment-3935014
Thanks SK and Duncan
I will need to take some more weight off my car in the future. My current weight is still too heavy. My rear left is a around 40kg lighter than the rear right. Is this common in the gtr? Can you guys offer some suggestion?
https://www.sau.com.au/forums/topic/131192-balancing-car/#findComment-3936413
The rear left being lighter is normal, the driver is on the RHS after all. The usual corner weighting adjustment is to shorten (take weight off) the RHS rear to compensate.
Cheers
Gary
https://www.sau.com.au/forums/topic/131192-balancing-car/#findComment-3937388
Forgive my noob comment, but how do they take weight on or off, is it just by adjusting the height slightly at each corner?
thanks guys
Obviously the best way to adjust the corner weights is to move something. An example, moving the battery from the front (which is the heavy end) RHS (which is the heavy side) to the rear LHS makes a useful difference. But when you run out of things to move, then adjusting the height of each corner is the go.
Cheers
Gary
https://www.sau.com.au/forums/topic/131192-balancing-car/#findComment-3938241
    • The new project has arrived. I have wanted one of these for such a long time, well before that meathead Clarkson drove one in Africa. I really wanted an E34 but I have some medical issues that mean I *really* can't bump my head and the lack of airbags in the E34 made it just too big of a risk.  I don't know why I've always liked these older touring BMW's to be honest, but man I love this car. She's been pretty well maintained for her 243k's with what appears to be only a single oil leak at the oil filter housing gasket. It has a bunch of updates including later model bumper and headlights, 7 series billion-way adjustable seats and it came with a few spares and another set of wheels with legal tyres. I got a unregistered car permit from the RTA and drove it back from Canberra on Saturday.                   First cab off the rank is cleaning it up for blue slip. I dont know how picky they'll be but I figured I'd clean the headlights, fix the oil filter housing gasket, replace the speed sensors (throwing errors) and swap the OE wheels (the M Sport wheels have a big chunk out of one of the tyres.) I also need to replace all 6 gas struts - 2 for bonnet, 2 for hatch and 2 for hatch glass. The car tries to eat me whenever i open any of these. My plan for this car; Ultimately, this is a budget car. I can't afford to throw lots at it and its because I have another car that I got this, if something breaks its no big deal. I will just maintain and repair it really. But eventually I want to do a manual conversion. It actually looks pretty straight forward for E39's and the trickiest part will be sourcing the parts.  I do need to replace some suspension arms or bushes because wow, she's a floaty old girl. She's also fantastically slow. Like really, really slow. When pulling back out on to the freeway on Sat after a quick pull over I needed to wait until no cars were visible before going.  Oh, and the guy I bought it from had a gorgeous R31 GTS-X in the garage.
    • Do you have a picture? I assume it is a breather for gearbox oil as it expands, it should have a vacuum line run nice and high in the engine bay (R32 GTR has it on a top bellhousing bolt)
    • Hi all, I am putting an r33 gtst gearbox into a VL and have noticed what looks like a vacuum barb on the box (on top in the middle). Suspecting that it's a vacuum line but I'd like to double check, if someone could confirm the function of that would be great. Cheers in advance.
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
