OK, so I've got an HKS catback, a high flow cat and a split front/dump to go on, yay me. Problem is that the damn dump pipe wants to stay behind. How the hell do I get access to the bolts on the dump pipe? I tried removing the turbo heat shield, but can't access those either (I'll probably drill out the top bolts anyway) here's the pix:
Anyone know a trick I do not? A tool I can use? I'm soaking the bolts overnight with WD40, and I'll have another crack tomorrow night.
https://www.sau.com.au/forums/topic/131204-removing-dump-pipe-and-heat-shield/
^^ yup what evan said..
Soak the crap out of those buts in wd40.. wait for a good 10 mins and try it slowly so you dont snap them..
Ohh and do this when your car is cold..
For best results do it on a hoist with the right tools!!
be patient and it will come off.
i'm about to do this myself, so i'll let you know. BUT what i have done, is WD40 the dump pipe everynight, so that when i come to take it off it will actually come off, LOL.
BE aware, you WILL loose some skin off your knuckles, TRUSTME.
BUt main thing is be carefull, and use the right tool.
i used a long hollow alluminium pipe over the spanner/wrench as leverage. makes it a little bit easier. gonna have to get under the car to remove the those last 2 nuts though. the heat shield is pretty straight forward, just undo all the bolts.
The problem with the heatshield is the wo bolts on the side, There is only a couple cm clearance, so a socket is out, and there's very little gap to actually move a spanner.
And underneath, same problem, I can get the spanner on, but can't revolve it, and getting the leverage is tricky (I stripped a socket already, hence the WD40)
I just thought I must have been doing something wrong, as most people have called it a 1/2 hour job, but when the cars just up on some wheel ramps, and all I have are a few 13mm spanners and some shifters, it makes things trickier.
Oh well, Off to bunnings.
Seriously guys, this is at most a one hour job but you need some decent tools and maybe to learn to modify and bend a spanner or two.
The right sockets and extensions will make life easy as well.
1. remove the O2 sensor using a large shifter
2. get rid of the heat shield. sockets/open end and large offset ring spanners are your friend
3. unbolt the top of the dump
4. jack the car, use safety stands and drop the engine pipe
5. unbolt the rest of the dump
6. replace in reverse order
Be prepared to reach in and use some muscle. Don't worry about a bit of grime, it only washes off
i agree with gtrgeoff with everything except for 1 thing. the o2 sensor is very hard to get out while the dump pipe is still on. it is easiest to take it out after you have removed the dump pipe.
i found i could get the 4 bolts out from the engine bay, and had to get the 2 nuts at the bottom off from under the car.
Never had a problen using a 12" shifter. You holding your tongue right?
i was using a 12" shifter too. the problem was the angle that it was on, i couldn't get the shifter on unless it was near vertical to the dump pipe. if the o2 sensor had been 1/4 of a turn in either direction it would've been fine. but i didn't seen any point stuffing around with it for half an hour while its in the car, when i could just do it when the dump pipe is out of the car and do it much easier. it doesn't make any difference to the rest of the job, so if you don't get it out first attempt when it is in the car, just take the dump pipe off, then take the sensor out.
OK, got the bitch tonight.
To others trying this, a couple of things.
1. you'll need to cut a 13mm spanner (I used a ring one) in half to get the top drivers nut.
2. There is no such thing as too much WD-40. Spray that stuff on there until your eyes water, then spray some more.
3. Anyone want to buy a stock exhaust, front pipe, cat and dump pipe?
hahaha
SOOO true Im in the middle of performing the same stunt and i used a whole can I was so pissed off at it! Just be warned that too much and you cant use your tools due to the shedload od WD40 youve used
OK, the pipe is on, but, true to my luck, there is still one problem.
one bolt (the centre line passenger side) won't go in. It just does not bite the thread and bore in. Naturally, it's the hardest to get to. I've tried a new bolt, more WD-40, extra force in all to no effect. I even tried to get a smaller bolt in there, but there is no room for the nut.
Any suggestions? Just how necessary is the middle bolt? (I've got the 4 corner ones in fine, and the centre drivers side went in too)
The cat and cat back is on no worries.
    • Here is a recipe. Sonic blocks till you get one that has a good enough bore. Get a torque plate and block brace, use your choice of fasteners (arp ect) bolt the thing together empty, half fill it and let it cure. Release it when it has, go to a REPUTABLE RB Builder and get the thing line bored/honed and cylinder honed to size, then wash. Once its all clean and dandy, wash and blow it out again. Then again.  Assemble said engine to your desired clearances with oil control mods, gasket to suit desired CR/Squish ect. Attach your extended sump with proper trap door oil baffles and head drain plumbed to sump with a SUMP BREATHER SYSTEM. Build your front diff with a decent LSD, rebuild your transfer case with a few extra plates, more than likely replace your tailshaft centre bearing and tighten up the rear diff. Tune to minimise excessive midrange cylinder pressure (timing unless you like to split bores and rebuild engines) Enjoy your engine, but hate the fact you are now destroying engine mounts, gearboxes, gearbox mounts, diff output flanges and driveshafts, diff mounts, tailshafts and front CV's.   Disclaimer.... Ive never done any of the aforementioned stuff.......
    • 440s will support well over 400HP on petrol, which is a decent place to be for an RB20. 230+rwkW. Will be a safer bet for idle/low load. 550s would be nice for the extra headroom. I've made the same decision with mine (Neo25). 1000s are probably too big for the Nistuned ECU, so I have some smaller ones.
    • Appreciate everything guys. I did go ahead and get an alignment... most of my complains are solved. Car is not perfect, but it's good enough. If I notice uneven tire wear or anything I'll just take everything back to stock.  Thanks again!
    • They still have not shipped the 550cc injectors as they weren't in stock, so in theory I could ask to get the 440cc ones instead, if those work better in my scenario. They're the same price so really shouldn't be an issue. Unfortunately I am not so knowledgeable in most parts of tuning so I wasn't sure what's best to choose between the two. 440cc ones are the lowest they have (not in stock, but available to buy nonetheless).
