The car:
Stock healthy RB20Det.
Only mods were:
2.5" CAT back
AVO muffler and catless (no dump)
Good air filter element (no pod)
Iridium plugs
Simple solenoid boost control
+ 3 deg timing.
Stock BOV, Fuel pressure, injectors, intercooler, coils and ECU
The car was set up for Targa 04 category 7 (1982-90) L2 (Lightly modefied). It produced 139.5 rwKw at stock boost (10 psi). At + 3 advanced 145.5 at stock boost. At 12.5 psi and the timing it was 150.0rwKW on the dot. All done on a DYNO DYNAMICS DYNAMOMETER by Bradd Sherrif in Launceston on a mild April evening.
One year later - after a whole season on the circuit and a Targa Tasmania - the plan was to get 170rwKW. So 13.5 psi and 98 RON plus a little bit more timing was the go.
After run 1 in old set up all got was 141kw. Put down to weather conditions, old plugs and engine a bit worn? Put boost up to 13.5 psi - got 145.6kw.
Emptied out PULP fuel and put in 98 - and lowered boost to 10psi just in case. 128kw was result. SHOCKED. Put boost up tp 13.5, resulted in 137.5kw - even more SHOCKED. Bradd was in disbelief. Did 2 more pulls, same result.
Conclusion: The standard RB20DET likes PULP and the ECU is obviously set up for it.
Further info: It has since been mentioned that the ECU works on FUZZY LODIC and is in constant re-tuning mode which takes time and probably would have produced better results if run on 98 fro a while. Also if we had disconnected the battery for a while it may have done the same thing.
While I'm no expert on this - facts are facts. But - with a programmable ECU (the HALTEC here now) and the same set-up with 98 I would expect my 170rwKW.
Kerry
https://www.sau.com.au/forums/topic/131222-98-ron-can-cost-you-power/
I'll be suprised if your make less power on 98, but to take advantage of 98 you're car has to be tuned for it. That may mean getting your ECU to relearn what it knows if its stock...? Fact is higher RON rating means it can take more heat and you can wind more boost/timing into it before it starts pinging....
Kerry is not the only person that is experiencing this. I have contacted BP, but not responce yet.
After speaking with a few people over the last few weeks since its introduction there have been mixed results with 98RON and re-tuning.
One thing i have noticed with most people's varied results was that they all still retained the stock ECU and was just running a SAFC/AVCR or manual boost control.
I will retune my car to 98RON with the new motor (being done in Melbourne by Dr Drift) and hopefully i will see better results (more torque :wave: ) so its even better to slide!!!
ferni is right.
98 RON has a higher knock rating hence you can run higher cylinder pressures and resultant heat before you get knock. Mixture is a very important component and maybe the standard ECU's just dont provide enough movement in the tune specs.
After market ECU and try again.
If you still dont make more power which logically you should then maybe the 98 RON aint quite the 98 RON we expect??? Big question to BP then eh?
My two bobs worth. :O
Cheers
Greg
Stu, who supplies Sunaco GT Plus (102). Might be good in a boosted 4age eh?
Japan's regular unleaded is 98RON and most of my imports i've owned (or still own) have 98RON fuel stickers on the fuel flap, so I'd say there is more to it. As mentioned above, the ECU may need a reset as it does "learn" to a certain degree, although shouldnt have a huge impact. Also, is the fuel from the bowser really 98RON???
i think it logicly has to be the ECU needing to re-learn. which isnt a big deal, ither run a few tanks of 98 or disconect the battery and try again wich sucks.
but this raises another question, is the 98 realy 98, how would the average person know as they pumped it in, its all in the mind that your car is going better and as proven by kerry its not, at least not on the first tank.
as for me im still running PULP and i cant realy see the point in paying more for the product yet as it only drives from a to b and hardly hits boost.
another experiance i had a few weeks ago was i accedentaly put normal unleaded fuel in (it had been a long day) and i didnt notice one bit of difference. not saying this is a good idea just i cant tell what fuel im running.
agreed with there, i have used normal unleaded at times and not noticed a fricken difference. but the car would have been fairly stockish and far from its limits. having said that, the engine can be pinging without you knowing it, obviously when you ARE aware its pinging then its pretty serious at that point.
Thanks for input guys.
From what I've read and heard.............
Octane rating, RON (Research Octane Number)
The most important characteristic of gasoline is its octane rating, which is a measure of how resistant gasoline is to premature detonation which causes knocking. It is measured relative to a mixture of 2,2,4-trimethylpentane (an isomer of octane) and n-heptane. There are a number of different conventions for expressing the octane rating therefore the same fuel may be labeled with a different number depending upon the system used.
Energy content
Gasoline contains about 32 megajoules per litre (MJ/l) or 131MJ/US gallon.
Volumetric energy density of some fuels compared to gasoline:
From this, an amount of petrol regardless of RON has the same amount of energy or BANG as any other RON petrol. From other info - I think the higher the RON, the slower it burns. A higher RON won't give you more power - but the ability to tune a motor to give more power. I suppose somewhere there is info on ratios of flame speed/burn, compression, piston speed etc. From here in it's getting into a black art.......that I leave to the engine tuner.
Any info on after market Jungle Juice appreciated:
1. Name, info on it
2. Distributor + ph no.
3. Price.
4. 1st hand experience with it.
Kerry
My experience is the same as Tasr32's. Chewed the shit aswell, barely even got 300kms to a tank on a relatively stock RB20DET. I can get about 400 on Shell PULP and it runs really well also.
Its funny how people have an opinion that 98RON is worst than the 95RON PULP that they use at the moment on there stock car!!!!
REMEMBER that your car hasn't been tuned to 98RON and there are a number of factors that can influence performance gains with tuning.
Just filling the tank up with 98RON instead of 95 isn't going to give you magical perfromance gains.
It does seem that the first impressions of some people that have had there cars tuned to 98 is a little disappointing considering the rest of Australia dont seem to have these problems that we are experiencing here in Tassie at the moment.
Having said that i run the 4X4 on PULP (was running a worked 202 now has a 454) and i found that once we got the 2nd float running right in the carbs and replaced the pick up that the truck ran better on the 98 than the 95 and its not reving as hard as it was original when we had a load on.
Now this is a little different given its not forced induction, its not EI and we run a set of 34's with cruiser diffs and now a different box, so the ratio's are different and i know that contributes to the rev factor, but while towing a load it does seem to run better on the 98.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
    • Every one has seemed to of have missed . . . . . . . The Mazda Cosmo . . . . . . what a MACHINE ! !
    • I might have gone a little more South Efrican.  But this is off topic.   😍😍 FD 😍😍
