1989 Skyline GX manual sedan Victoria
red duco
tan interior
air con
power steering
RB30ET (VL turbo motor and computer, standard boost)
8.0:1 comp with shaved head
Ported and Polished head
AVO stage 3 cam
cold air induction with pod filter
2.25 inch exhaust
Spitfire Boost gauge
NA inlet Manifold with turbo injectors
R32 5 speed manual gearbox
heavy duty lowered suspension
Monroe GT gas shocks
replaced rear bushes and some front
15inch alloy's with Falken rubber
meshed front bar in middle and where indicators are
indicators moved to parkers
Import projector front lights
fog lights behind mesh in bumper
GTS grill
Tinted windows
tow bar
Warlock Alarm
3 stage shock sensor
3 stage immoblisation
motion sensor
doors and bonnet sensor
plus other features
Panasonic head unit
Audioline 2 X 300 watt sub amp
JVC 4 X 80 watt RMS amp
Kicker 6.5 inch splits
Pioneer 4 way 6 x 9's in custom parcel shelf
12 inch Kicker sub
Uniden CB AM radio
removable boot mount base and aerial
PLUS SPARE PARTS
original motor for this car (complete block and head)
power steering pump
air con pump
starter motor
one complete turbo head and cam
one complete NA head in parts
AFM
water pump
VL turbo wiring loom
two turbo inlet manifolds
4 or 5 turbo injectors
6 NA injectors
intank fuel pump
two rear rotors and calipers
diff, with centre and axles (sedan)
NA extractors (not sure of brand)
2.25 or 2.5 inch exhaust (needs to be welded together)
stock NA exhaust manifold
NA auto computer
NA manual computer
one pair of series 3 headlights and front indicators
NA air filter box, snorkel and intake
Car has done 220,000kms and has been turbo charged for approx. 5,000kms. Original service books supplied.
Inspection will not dissappoint
Asking $10,000 ono with all parts.
Will not seperate parts until car is sold.
No pics.
Ben
0413786329
[email protected]
Melbourne, Victoria
https://www.sau.com.au/forums/topic/13123-r31-3ltr-turbo-skyline-vic/
  • 1 year later...
  • 2 years later...
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
