  • 2 months later...
after trying all the 98+ fuels for a long time now, the best one i always thought was BP Ultimate (although there wasnt a massive diff), However recently i been using Vortex 98 and out of all the fuels, i think personally vortex 98 stands out, even more than the Shell 100 RON fuel. This is just my opinion. Fuel economy wise, well how do u ever measure fuel economy? unless you never gun the thing, and lets face it, not many of us would go through a full tank of fuel without pushing it here and there so its really hard to measure fuel economy.
most skyline drivers will need to do an ECU reset and run-in (~1000kms) to notice any differences between fuels
i've been running optimax since i bought my car, and when the fuel prices plummeted i switched up to optimax extreme (v-power racing) and noticed a little increase in response.
I've reset my ECU, just coming up to the optimal run-in mileage now and my car goes like a burnt cat. Stupid amount of response and acceleration, hardly even notice it's an NA :happy:
Afaik the 100 octane + 5% ethanol blend is what the japs use and what the skylines are supposed to run on, so that's what's staying in my car from now on, i love it.
yeah i ran the ultimate in my n15 with rnn14 and it was getting about 350-400 per tank ive had the v power racing in for a monthish now and i get 450-500 and i can def notice its alot smoother on accelerating and has bit more punch but nothing over the moon...
mainly use optimax inthe gtr no v power racing on the coast near me yet but have had the ultimate and no defference in both so far.... i have had caltex 98 in the sss and wasnt good but couldve been a bad batch.
just get some martini racing fuel 110ron hehehe
I only use Caltex Vortex or 91 (Not in a skyline, waiting till I am 21 now - just a ford falcon)
It is only about 7c more than 91 at my station, and nambour generally has the cheapest fuel in the sunshine coast (Normal Unleaded was 100.9c today compared to BP 104.9 AND I have to go out of my way to get to BP).
I put a tank of V power in today, I noticed smoother acceleration, cant say its got more power but I do like it, I'll let youz know what mileage is like when I fill up next.
It's funny that we still use the word mileage but kilometreage just dosnt sound right, does it?
    • Coming home late at night and driving past the police is the only reason i need one haha And yeh, definitley needs a switch to quickly enable it, dont have time to be getting my phone, opening an app, waiting for it to update etc before being able to make the change
    • Because it is financially convenient for them lol. Why wouldn't they want to give you the lowest possible valuation for your car?
    • Yep. @Duncan also shannons they will rip you dry and will be probably limited on how much you can drive. Also keep in mind that you always have to have it garaged with Shannons, with enthusiasts as per their PDS you can have it 2 times per week on the driveway for example.
    • I had a generic 4" Varex rear box on my old V8, worked a treat for sneaking home late at night, it was as quite as stock when closed The car was "fairly" loud when open as it consisted of 1" 7/8 headers to 3" catted Y pipe, to 4" single, it did have a resonator in the mid pipe and only the Varex out the back I also hard wired in a Varex dash mount switch, as the key fob thing is a pain to use when driving I wouldn't recommend giving the beans when it is closed though as it creates a large restriction in the exhaust  It also can in very handy when pulled over for "random" breath tests or just cruising past the constabulary
    • Here is the before and after of the scraping/sanding of the IC pads on the tachometer board for the fix mentioned in this thread. And yes it worked fine after. Just a note if you change any components on the board the tach calibration can be wrong showing the wrong idle etc...only problem is once it is installed back in the cluster you can't get to it to adjust...ouch! My fix was to cut out the calibration pot (the blue one) from the board and run it with two wires to the fuse panel under the dash where I could adjust the idle calibration once everything was installed. And yes I soldered everything up again including the half soldered components either side of the IC in my photos
