as the title of this area states:
Welcome to the Tutorials / DIY / FAQ Forum! This section of SAU is where we move the helpful threads that we find in other forums. This is *NOT* the place to ask questions or to try and get help. Please use the other appropriate forums for that.
I have moved your post to general maitenance
https://www.sau.com.au/forums/topic/131278-r32-question/#findComment-2428923
When you say cluster, if you mean the 3 gauge cluster from the centre console, then yes. To make it actually work will be around $500 in OEM parts. For the same money you could fit some nicer aftermarket gauges. Up to you.
If you meant the instrument cluster or instrument panel: you won't be able to make it work. The plugs are different and things like the torque split gauge are obviously superfluous.
Cheers dude.
https://www.sau.com.au/forums/topic/131278-r32-question/#findComment-2433153
