All this was going to go into my LS400 but it will be getting sold soon so all the car audio equipment is for sale.
Some items are brand new still packed in orginal boxes and some are second hand items I purchased but never used.
Can email high res and other pictures on request.
Email me at [email protected] if interested in anything
Brand New Items Still In Original Boxes
JVC KD-DV6105 – CD/DVD/WMA/MP3 Player
Price - $400
Front AUX Input ensures easy connections with external audio devices. Superior sound is made possible by a MOS-FET amp, 24-bit resolution DAC, and Digital 7-Band iEQ. Dual Zone is also available.
Front AUX Input
The KD-DV6105 comes equipped with an AUX input conveniently located on the front panel. This permits easy connection with external devices – including digital audio players – and easy enhancement of your in-car audio entertainment.
Highlights
• Power Output: 50W x 4 Max.
• MOS-FET Power Amp
• GIGA MP3
• Digital 7-Band iEQ
• DVD-R/-RW, +R/+RW, VCD Compatible
• MP3/WMA Compatible with ID3/WMA Tag
• CD/CD-R/CD-RW Compatible
• DTS/Dolby Digital/MPEG Audio (2ch)
• 24-bit DAC (Audio)
• Adjustable Line Input Terminals
• 5V Line Output Level
• Line Output Terminals ( x 2 pairs)
• Front AUX Input
• Video Output Terminals
• Second Audio Output
• Subwoofer Output Terminals with Level/Frequency Control
• Optical Digital Output
• Flip-down Face
• Rotary Encoder Multi-Control
• Dual Zone Function
• Multi-Function Wireless Remote Control
*In conjunction with KS-PD100
DVD Section
• Video Format: NTSC/PAL
• Chapter Access (for DVD)
• Pause/Step/Slow*
• VCD Playback Control
• Direct Track Access (for VCD)
• Last Position Memory
*Remote control only
CD Section
• CD Text
• Disc Name Registration
• Random/Repeat/Intro Play
• +/- 10 Skip Function
Changer Control Section
• MP3 Control*
• CD Text*
• Direct Disc Select (1-12)
• Random/Repeat Play
• Skip/Search
* In conjunction with CH-X1500.
Tuner Section
• HS-II Tuner
• 18 FM and 6 AM Presets
• SSM (for FM)
• Seek (Up/Down)
• AFNS/PNC
• Stereo/Mono Switch (for FM)
• Auto Antenna
Amplifier Section
• Source-Specific Volume Control
• Balance/Fader Control
• Volume Attenuator
• Loudness Control
• Max. Amp Gain Switcher
Display Section
• Blue-Color Display
• White LED Backlight
• Switchable Dimmer
• Level Meter
• Power Switch Standby Illumination
General Section
• Detachable Control Panel with Carrying Case
• Tel. Muting
• Power-Off Mode Eject
• COMPU PLAY
• Preferred Setting Mode
Splits Pods
Brand New
Made from fibre glass. with a grey cover and an MDF base which bolts to the car.
They are approximately 10 cm deep at their highest point and about 3 at their lowest.
Angled towards the middle of the car so the sound is directed at you.
Designed for 6.5" Mid and space for a tweeter to be mounted also.
Price - $50
Used
MTX 12” Sub & Box
MTX Thunder 400 Sub And Custom Made Box
Max Power 400w
Dual Voice Coil
Normal Power 250w
Price - $180
https://www.sau.com.au/forums/topic/131283-sold/
  • 1 month later...
  • 3 weeks later...
    • It's the adhesive holding the ceramic wheel to the shaft the fails on 90% of them.
    • Foreign debris, physical shock, boost leak, could be anything honestly. The danger in taking all the timing out of a tune/hitting the R&R corner is that even if the engine doesn't detonate your turbo is taking a lot of abuse from high EGT. Also, even if nothing goes wrong it is a journal bearing that is spinning at 100k RPM on boost. Eventually it goes through enough cold start/pressure cycles to wear it out.
    • I kinda accidentally saw this, and was interested, but It actually seems to replaces the whole center computer, using the existing screen and buttons. AND it may only be for a G37 and not compatible with a Japanese 370. So its not for me, but someone else may be interested to look into it. Its about $680USD. If I am understanding it right, it basically replaces/installs and android pc that integrates with the existing screen. But I could be wrong. https://gromaudio.com/vline/ The video I first saw was the following, with very little and unclear details.     Even if your not interested in the system, the video on their site was pretty comforting in showing how simple the whole centre comes out
    • hfygrte52 what side you looking for? Do you care what color car it's off? Found a white LH side on here: https://skylinespares.com.au/product/nissan-skyline-r33-coupe-rear-tail-light/   Aussie parts place but will ship to USA. Maybe get it before there's a tarrif on 25yo shit box parts
    • I’m with Shannon’s for all 5 of our cars. Agreed values seem fair, premium price is okay. ($210 ish a month, all comprehensive).  Have claimed once with them for a not at fault claim with another car where my car had no damage. Was one call after the incident and an email after. Deemed not at fault so premium didn’t go up either.    I have called up and spoken with people who are not familiar with certain cars and didn’t agree with me on value or let their personal vehicle preferences effect the call. But called back later and got someone else who was more agreeable.
