good one numbnuts u wasted money phoning japan ur a PLATINUM DICKHEAD then arent you! do whAT Ever you want if you don't like what i write DONT read it !
at least i can wave my dick around and it aint stuck up my arse>
seriously u ahole im helping people here go and hassle sum1else
  • Replies 107
Guys - time for a group hug
:grouphug:
OK, the attached pic is the pipework and solinoid off of my series 1 R33 GTS-t.
See the hose on the left how it has a red band around it. Well that indicates where the restricot is in the pipe.
Have a look.
J
Can someone explain to me how adding a restrictor to the wastegate line can *limit* boost rather than raise it (or at least postpone it)? This is a serious question - as I understand it, placing any restrictor in the wastegate line will slow the response of the wastgate actuator in relation to the manifold pressure. Obviously if some well-respected people like Mark Tillbrook are saying that doing nothing except removing the restrictor will give you more power, then there must be some truth to it. Can anyone clear it up with a solid explanation?
JAGR33 - sounds like your car is a bit of a weapon :P Not disputing your claim of a power/boost increase, but I would suggest that much of this increase came from the cam gears. It's amazing what effect dialling in the cams has on not just the running of the engine, but also the building of boost due to different valve openings. Also, if the exhaust and pod were put on at the same time then they would also have a sizeable impact on boost. At a guess, the reason so many people recommend removal of the restrictor is because it makes it difficult for an aftermarket boost controller to have "full" control over the wastegate - a case of too many cooks, if you will. On a stock engine (or at least one with the factory wastgate system in place) I would leave it in, or risk losing boost response. Again, correct me if I'm wrong and you can back it up with a solid explanation of why.
I'm not going to dispute the presence - or lack thereof - of a restrictor on a non-GTR because I just don't know, suffice to say that if your car has ever been in need of a wastegate line replacement, I dare say it was replaced with standard vacuum hose, without a restrictor, as it'd be cheaper and easier to get hold of than the genuine Nissan item.
The restrictor is there to limit the volume of air going to the bleed valve (or factory solenoid) to ensure that boost is controlled better.
Many tuners (even ICE) use restrictors in the line going to a bleed valve to limit the volume of air the bleed has to "bleed off" so that spikes can be reduced.
ADAM SERIOUSLY IF I WANT TO USE CAPS LOCK I WILL OTHERWISE MIND UR OWN BUSINESS, AND YES I AM AN AIRCRAFT MECHANIC AND THIS IS A RESTRICTOR AND NO IT WONT CAUSE THE TURBO TO OVERBOOST ALL IT DOES IS FREE UP THE VACUUM LINE TO ALLOW MORE BOOST TO BE APPLIED BUT IT WILL ONLY BOOST TO 7.5PSI WITHOUT AN EXHAUST OR WITH AN EXHAUST 10 PSI . GUYS DON'T WORRY THIS WILL NOT HARM UR TURBO OR MOTOR. ITS BETTER THAN CUTTING WIRE 53
I don't understand how "freeing up" the vacuum line will allow more boost to build up? :confused:
By this logic, more pressure in this line will mean the wastegate shuts earlier = less boost
Also, it is normal for a std car to boost to 7.5psi and then to 10psi with an exhaust with no other changes.
Revhead, I see what you are getting at, but from what I've experienced in the last week, tells me that there is a difference with taking out the restrictor.
Just to clarify, my full exhaust and pod filters were installed months ago, therefore they wouldn't have increased the power from 185rwks to 215rwkws. Once I took the restrictor out, the dyno showed 200rwkws (boosting to 13.5 psi, but holding 12.7psi). Therefore an increase of 15 rwkws. Another 15rwkws were extracted from dialing in the cams.
Also my mate took out his restrictor in his R32 GTR and reckons the car boosts much harder, and an increasing in performance. We're not talking 'mind blowing' difference, but its definetly there.
As far as technical explanation goes, I can't help you there but I definetly experienced a difference....
Hope that clears things up.
All this talk of removing on a 33... are we sure we WANT 13-14psi on the stock turbo? I've read so much about stockers only holding safely around that figure, why would you want to remove the alleged restrictor?
Guest 570CK
Buy a bigger turbo then :(
    • I had absolutely no symptoms whatsoever that anything was wrong.... I'm very happy it was all spotto'd and re-bled and re-torqued and aligned though. Will be picking it up tomorrow and undoubtedly be like "Oh, that clunk is gone" "Oh, the car really wants to drive straight" "Oh, that pedal feels better" "Oh, it feels like I've gained 25hp" "Oh, the handbrake works now" It should have been a sign that the new Project Mu shoes had 3mm of pad depth on them out of the box, and the OEM ones from 25 years ago that we took out also had 3mm of pad depth, implying the issue was not, and never was the shoes, but we put that down to it not being adjusted correctly. It wasn't, but it wasn't even adjustable at all given one side was boned and the T Junction of the cables was on a 45 degree angle, the non-working side being the one on the massive angle. Obviously when I had adjusted it and reset it and re-tensioned it I had either got it stuck or something along those lines. Oh well. Live and learn and absolutely could have been catastrophically worse so I'm rationalizing it as a win, kinda. I also got the chance to measure the distance between rear rim and the suspension arm/shocks and found a 30mm rubber block only just doesn't fit there. Which is great to know before ordering wheels, when I assumed 30mm was easy. The man with the Porsche adapters has rims that use 23.9mm of that space, so it's safe to assume I have between 23.9 and 29.9mm of space there to play with on the inside. The wheels looked pretty stupidly pokey with the 20mm spacers on the rear, only for me to find that the studs come out another 12mm and the wheel doesn't actually sit flush with the hub because you're supposed to cut your original studs. The wheels do have cutouts that kinda accomodate it, but not fully. So my 20mm spacer was anywhere between 25mm and 35mm. ~25mm and send it will determine on where the wheels sit with the spacers on. When I put the pads in for the track day I will mess around with spacers (with wheels that do not clear studs properly when mounted to spacers) and do more math, for the last time, for the 7th time.
    • Lucky pick up Best to find these things before something horrible happened to the yoke flange thingies I would hate to think what would happen if it dropped the tailshaft  Hopefully the holes are not flogged out in the yokes and it was just the bolts that got munted  As for the hand brake.....ouch, look like the disc got rather hot, and I assume smokey, I recall when I had a front caliper seize on the Commodore, there was lots of smoke and the disc was glowing cherry red when I was able to eventually stop and have a look, and stopping a big heavy car, going down a big hill with some rather high RPM down shifts and some hand brake action is something that makes you think hard about life
    • One of the things that never seemed right was the handbrake. Put in some nice new Project Mu shoes. We figured the rears were out, so why not. We're right there. My handbrake never worked well anyway. Well, this is them, 15km later. 67fdcf94-9763-4522-97a4-8f04b2ad0826.mp4 Keen eyes would note the difference in this picture too:   And this picture: Also, this was my Tailshaft bolts: 4ad3c7dd-51d0-4577-8e72-ba8bc82f6e87.mp4 It turns out my suspicions that one side of the handbrake cable was stretched all along were pretty accurate, as was my intuition that I didn't want to drop the tailshaft to swap them on jack stands and wasn't entirely sure about bolt torque. I have since bought the handbrake cables which have gone in. I'm very glad that I went to my mechanic friend who owns an alignment machine to get an alignment before the track day, because his eyes spotted these various levels of "WHAT THE f**k IS GOING ON HERE?". Turns out the alignment wasn't that bad, considering we changed the adjustable castor arms out for un-adjustable castor arms, and messed with the heights. Car drove pretty good with one side of the handbrake stuck on, unbleedable rear brakes, alignment screwy, and the tailshaft about to go flying and generally being a death trap waiting to happen! (I did have covid) (I maintain I adjusted the handbrake correctly, but movement caused shennanigans and/or I dislodged the spring on the problem side somewhat, or god knows what). G R E G G E D
    • Very interesting, im not sure how all those complications fit in to running a haltech instead of a stock ecu but I'm starting to think I'm a bit out of my league.
    • I just put 2 and 2 together. This is a Neo converted R32. The Neo ECU (in concert with the R34's AC controller) runs the AC quite differently to how the R32 ECU and AC controller do it. If you just drop it all in, it won't work. There is some tricky wiring required, including changing to the pressure switch that the Neo controllers want to see. I don't know what it is, because mine was done by a guru. It was a year or so after I did that transplant before he worked out what needed to be done.
