  • Replies 89
anyone remember that veilside widebody that used to belong to UPI (plates were BNR32). that car was hot! its the only widebody that i liked (and surprisingly made by veilside, who in my opinion, make a lot of shit kits). pity they are so damn expensive! anyone know the going rate for them these days?
not sure if anyone in aus has imported the genuine veilside WB kits for 32 (except for ones already on cars). I will probably call in to veilside first week in november so if it's no trouble I'll find out what they charge for them these days.
sweeeet. all i need to do is sell one kidney and i should be right!
yeah, veilside do have some terrible kits but their widebody 32s have so much prescence in the flesh. they look amazing. i even like the veilside mariott wheels they put on them. suit the cars very well.
i'm interested to hear about shan's case also...
the fibreglasser we contracted to do the mould sold a copy to the company that supplied ali's kit. he was swayed by extra money thrown at him (seeing as they charged ali for a genuine kit i'm sure they had plenty spare)... nothing much we can do except call him names and give him a swift kick to the nuts.
Not gonna stress over it coz I'm over it. I've had the kit for like 3 years now... if people were that desperate for it they'll pay for a real one and copy it, so replica's are inevitable.
still feel pretty shitty about it though. shouldn't have even agreed to having the kit copied in the first place... now there's 3 cars in melbourne running around with copies of my kit and I still haven't had the time to put mine on... although Adam's one I don't really mind (red one at Autosalon) coz Adam's a mate.
...and I still haven't had the time to put mine on...
Hmmmm.... aaaaaaahhhhh..... mmmmmmmm.... yep.
I'd hazard a guess that it's never gonna be put on :O
I seriously can't be f**ked anymore... I originally wanted to build a show car, but after moving to sydney (with the abysmal road conditions) and getting more and more involved in motorsport the less practical such a big kit seems. So not looking forward to babying the car around and parking the car ever so carefully once its put on.
you have to cut away part of the inner guard, and part of the guard underneath, and fabricate a new innerguard so the wider wheel dosen't scrape on anything.
the widebody guard goes right up to where the boot joins the guard, the point where the roof meets the body on the c pillar, and wraps just inside the door jam in front (so that there's no obvious joins when you look at the doorline) and at the back goes to the tail light. If you do it properly it makes a totally seamless blend.
I am against modifying wheel arches and bonding glass to metal panels. It will crack,
There is one GTSt cruising around with the prelim copy that was pulled off the mould (which was supposed to have been destroyed, but I'm guessing that was sold too... heh). The owner of that car's just rivetted the kit onto existing guards. Without it being blended it looks like arse with a sprinkling of shite.
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
