What should he get for his bday??
39 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Happy bday damo :P whatever you get yourself i might buy your old shit to put on my car, the cooler is still going strong lol
My opinion - Chrome spinners FTW !! every black man needs chrome spinners right??
https://www.sau.com.au/forums/topic/131339-happy-bday-damo/#findComment-2430259
Happy Birthday Damo. I almost voted "A ROOT" but it seems everybody has that one covered for ya. Plus I'm sure with your manly physique you would have no problems with "pulling a root".
Instead, I voted for suspension so you can get your "slow 34" out on the track next year!!!! :O
https://www.sau.com.au/forums/topic/131339-happy-bday-damo/#findComment-2430633
Happy birthday mate!
The poll should realy read what should Damo STEAL for his birtday...as black men buy nothing
I say steal suspension first HKS Hypermax 2 is cheap and so far it has been pretty good for me!
Just dont steal mine :O
https://www.sau.com.au/forums/topic/131339-happy-bday-damo/#findComment-2430790
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
    • How much does the shifter move when the car is in gear with the engine off? If it is more than about 1cm you need to replace your shifter bush. Your shifts will just get crunchier, not faster, with a short shifter unless you also rebuild the whole box
    • I should video mine, will prob do it tomorrow    Between 1st and 3rd, you could fit another two gears. That is how loose and wobbly it is   horrible:(
