I have shattered the exhaust wheel of the lower turbo on my 1989 R32 GTR ~109,000km and need to get new turbos. The car is mainly driven on weekends with the intention of occasional track days. I have Peugeot 205 GTI as a daily driver.
Let me start by saying I did a search and have read the following threads:
http://www.skylinesaustralia.com/forums/in...showtopic=80624
http://www.skylinesaustralia.com/forums/in...126186&st=0
http://www.skylinesaustralia.com/forums/in...c=83371&hl=
http://www.skylinesaustralia.com/forums/in...121435&st=0 even though it's about a RB25 it had some good points to consider.
and http://www.skylinesaustralia.com/forums/in...=124176&hl= for a basic understanding of what turbos are and how they work.
Current mods (that I'm aware of):
Turbo back exhaust with high flow cat
HKS air pods
125mm Apexi FMIC
Apexi front pipes
Remapped ECU
HKS EVC set at 10 psi (low) & 17 psi (high)
Blitz BOVs
Heavy duty clutch (not sure of brand but previous owner didn't go cheap on anything)
Plus more stuff for handling, gauges etc not relevant for current project.
Stock dump pipes
Stock airflow meter
I believe it has standard injectors and fuel pump.
The car previously made about 250rwkW at 17psi
From the research I’ve done today I gather if I get R34 N1, Garrett GT2860-7, HKS GTSS or Garrett GT2860-9 turbos I will get about 250-270rwkW with good response and midrange punch without having to make any other changes. Cost about $4-5k with labour and tuning. What boost will achieve these power figures?
If I get HKS 2530 or Garrett GT2860-5 turbos I will get 300-350rwkW but will less responsive and be more peaky. I’ll also need to get 700cc injectors, a new ECU, fuel pump, dump pipes and spend an extra $400+ on tuning. Have I missed something?
I guess 2xGT2860-5, SARD injectors, a Power FC, N1 fuel pump and brand 'x' dump pipes (I’ll have to investigate these more) with labour and tuning will cost between $8-9k.
Is this all correct? What have I missed or should consider?
https://www.sau.com.au/forums/topic/131350-gtr-turbo-upgrade/
  • Replies 47
HKS air pods
125mm Apexi FMIC
Apexi front pipes
Remapped ECU
Blitz BOVs
Stock dump pipes
Stock airflow meter
Hi there,
The Project you are undertaking sound like mine.
700cc sard injectors,Nismo( fuel,oil,water,regulator)Splitfire coils, Iritop-7 plugs,Power fc,Avcr boost controler,HKS dump pipes,Manifolds,GT2860-5(which i have a set for sale with manifolds brand new).
You have missed the following.
New lines, Braided oil(smaller lines than the originals)
New water lines,also connected to the Turbo's
Gasket sets for Manifolds and turbo's.
New coil pack,
New Spark Plugs-7 heat range.
You really dont need a boost controller if you are happy winding up the actuators to 1 or1.1 bar.
You said dump pipes.....yeah you need these for the 2530's...oh sorry gt2860r-5...just so you can spool up earlier.
You might consider having some oil mods done ,prevention is better than the cure
Don't forget though.....cams and adjustable gears with stronger springs and bolts are required to get the full potential of all good turbo upgrades.
Oh then you will be able to go so fast....you need to upgrade your brakes....front only will do. :rofl::(:(:P;):laugh:
The list is never ending in a gtr
You missed some , but yeah 9K Plus /Approx will do it. My second set of -5 Turbo's i an selling with manifolds for $2800.(Brand New)..so shop around. Injectors i bought for $890.Coil pack for $700.Sparks$170.Dumps HKS $700.Fuel PumpN1 $550Approx.N1 Regulator $270.
Power fc $980.Allow $200 for lines and $200 for gaskets.Allow about $2500 for labour and Tune for these items.So do your sums.
Hope i have been some help
Regards
Tekin
PM ME if you want to know where i got these from .
Have you have the motor inspected yet?
More often than not... when a GTR lets a turbo go, it also gets ceramic bits into the motor and destroys a piston or two unfortunately.
GT-SS/N1's will net you 300rwkw... the 2530's are around the 340-380rwkw mark. Or even more, but then stocker motor, 2530's + 350rwkw equals a dead circuit raced motor.
Settle with the N1's/GT-SS/Garretts, which are all more or less the same.
300rwkw on around 18-20psi and will be a good performer on a stock motor.
Thanks for your replies Tekin and R31Nismoid. I have read alot of your posts today :P
I have already upgraded the front brakes (DBA 4000 rotors, Ferrodo DS2500 pads, braided lines and Castrol SRF brake fluid), the oil filter has been relocated with a GREX kit with all braided hoses, and I have an oil cooler and an oil catch can. The coils aren't standard but I don't know what they are. I'm using NGK platnium spark plugs. I use the presets on the HKS EVC as a boost controller.
I have booked a compression and leak down test which will be done later this week.
Your list came to about $10k Tekin which gives me a ballpark to work around - thanks. Did you get the hand controller with the Power FC?
"Don't forget though.....cams and adjustable gears with stronger springs and bolts are required to get the full potential of all good turbo upgrades." I was told that the standard cams were good enough for 350rwkW and didn't think I'd need to change them yet.
Edited by writeoff
RB26 benefits more than the RB25 in the cam department.
over 300rwkw i would be looking at cams. cam gear for upto 300rwkw, then cams + gear after that if your budget restrained
More seaching and reading to do. I think I'll wait to tomorrow to read up on cams and cam gear. At least I look busy at work :P
I have already upgraded the front brakes (DBA 4000 rotors, Ferrodo DS2500 pads, braided lines and Castrol SRF brake fluid), the oil filter has been relocated with a GREX kit with all braided hoses, and I have an oil cooler and an oil catch can. The coils aren't standard but I don't know what they are. I'm using platnium spark plugs (can't remember brand NKG or something). I use the presets on the HKS EVC as a boost controller.
David,
Yes Power fc came with controller....
You have chosen wisely(2530,s )
The cams and gears with stronger springs and bolts are only needed for peak
performance at high RPM...ie race track or drag. The standard cams are good for street and some track work.
Tune the car for good mid range response and enjoy.
On the other hand if you are looking for High Dyno results..and after track work aswell as drag .the above is needed.
The cams are roughly $1000 and gears about $400 Bolts about $500 Approx and spring $500Approx.I have not headed down this road yet,pricings are approx, but thought i could do it at a later stage of the cars development.
Take care
PM ME For pricing details for products.
As I said ,on a gtr the mods are endless.
I have used a pair of Trust T517Z on my GTR before with Cams, power FC, Exhaust, coolers etc...I was making 301kw@all wheels at 1.1bar
and now I up graded to pair of Tomei Turbos...still using the old T517Z maps in Power FC with heaps of lags making 394kw@all wheels....
if you are looking for cheap up grade..I can probably help you to get some brand new GTR replacement turbo (-10) for around $2900 to $3000. and with those turbos you can easily get over 340kw with stabdard internal.
generic garrets for $3K is not that great a price. for a very small amount more you could get a brand new set of HKS 2530s which come with gaskets, studs, lines etc. or for almost exactly $3K you could get a genuine HKS GT-SS kit which also comes with everything needed to install them. $3K for garretts is all well and good, but then you have a couple of hundred bucks, and some stuffing around to get all the bits needed to fit them.
if you want my advice this is what I would add to your current set-up.
either HKS GT-SS or GT 2530 kit
Power FC
Sard 700cc injectors
Nismo fuel pump
nismo fuel reg
tomei sump baffle kit
tomei type B pon-cam + cam gears
nismo airflow meters (or VG30 meters if you want)
This package will give you a meaty 300kw+ with very nice response when tuned properly. This is the secret, light tune GTR recipe for success. and it's been cooked up time and time again always with good results. oishi desu ne.
Thanks for your input Beer Baron.
A quick question - NISMO and N1 gear is differnet right. I have been searching for N1 gear and keep finding NISMO stuff but it doesn't specify whether it is from the N1 editions.
Also I was under the impression the stock AFM were okay up to 350rwkW so hadn't taken their upgrade cost into consideration. I am still finallising a kit list before ordering everything.
my advice again is if you want trouble free upgrade, with lasting results. then you cant beat the package I listed above.
again, 2XS15 turbos has a number of problems.
1. un tested and unproven combo
2. not the right flange (so need $$ spent on adapter, or different mani, or modding turbos)
3. still need to buy the right lines, fittings and gaskets
4. if they are used then i personaly thing $2500 (min) for a second hand un proven turbo set-up is a waste of time and money.
Nismo is nismo. N1 gear, i assume you mean like N1 turbos, N1 oil pump etc are all made by Nissan.
I'm sure you 'could' still use stock AFMS but it wont be the best result as they will reach 5.115 volts pretty early on and stay there, making a nice tune harder to achieve. my stock AFMS reach 5.115 volts on occaision and that's with 260rwkw.
trust me, stick to the above recipe, you wont regret it! sore wa totemo oishi desu ne.
I'm currently removing my turbos to install my GT2530's.
I was going to upgrade the dump's and front pipes at a later date. But after all the buggering round it's taking to remove my old turbo's, I’m 95% sure I’m going to upgrade my pipes now.
Do the trust dump/front pipes fit the GT2530's properly? As the 2530's have the partition cast in the housing to separate the wastgate and outlet. Also where can I get a proper gasket (for the partition)
Thanks
Edited by sav man
The workshop where the car is at is taking about using 2x S15 turbos at about $1100 each. Has anyone heard of or used this conversion before?
Hi David, :P
There are some who think they know and some who know.
Does the workshop have a dyno, and has it performed upgrades or mods on gtr's?
What power rating are these turbo's anyway?
Do they know the line sizes they need to use water and oil?
Have they talked to you about meeting your goals on performance?
Ask them lots of questions to find out if this has been done before, and with what results?
If they have not seen it or done it themselves before, your looking for trouble.
I would rather go with a proven set up before undertaking this set up.
To save a few $100 dollars , might even de-value the price of the car.
Take Care
Tekin
i just want to ask off the cuff ... what is involved in replacing the ceramic wheels in the standard set ups with steel components as far as dollar wise ? I am guessing a shaft , a bearing, a balance... someone should offer this cheap tp us poor porcilen victums .... Hard to swallow 13psi when your been useing up to 16 on an old battle axe...
I read half pissed the other day it was a reasonable upgrade per dollar but do you think i can find where i read that ....nooo doh!
It would cost around 1k per turbo as you would wanna get new cartridges etc. Being i had a GT30 rebuilt for that price... which was trade price, so could be a tad higher.
Rather than use the old core etc... so basically a new turbo :P
The Garrett copies of the GT-SS can be had for not much more than the rebuild cost of the stockers.
Or even a tad more coin and the GT-SS in-a-box hehee with all gaskets etc.
For the extra bit of ommph and top end i think it would be worth the slightly extra coin being that stockers rebuilt cost similar by the time you do everything (gasket replacement etc etc)
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
    • Was that Australia Delivered Duncan? Does it have siren etc?   I used to have remote start on an old 32 two decades ago, it was a cool feature. I used to wake up early in winter for work. Start it and by the time i was out the door a few minutes later the engine was warmed up and the heaters had the car toasty. It was great.    I don’t mine the ambience lighting.  I drive a western star and it has footwell lights and ambient lighting and it’s great! From the pics of seen of them installed in a skyline I think it’s a nice touch
