drgnball34 Posted August 22, 2006 Share Posted August 22, 2006 12mths ago when i brought my R34 GTT, i installed a avc-r thinking i wasnt going to much more mods down the track. Boy was i wrong! Now that i got a whole heap of gear for my car, i needed a power fc the run the show. thinking back, i should of just tossed the avc-r idea and saved abit extra and got the boost kit together with the power fc. I should be able to run both of them independently? The only real disadvantage is not being able to control boost from the handheld? Other then that i should be fine? Link to comment https://www.sau.com.au/forums/topic/131374-power-fc-and-avc-r/ Share on other sites More sharing options...
Stephen22 Posted August 22, 2006 Share Posted August 22, 2006 Nothing will be different rather you use the AUC-R with Power FC or only Power FC with boost kit....but Power FC with boost kit will be alot easiler when it is tunning tho Link to comment https://www.sau.com.au/forums/topic/131374-power-fc-and-avc-r/#findComment-2430374 Share on other sites More sharing options...
drgnball34 Posted August 22, 2006 Author Share Posted August 22, 2006 All i need is the harness to the power fc? Can i just buy that separately? How much and where? Link to comment https://www.sau.com.au/forums/topic/131374-power-fc-and-avc-r/#findComment-2430380 Share on other sites More sharing options...
Kennedy Posted August 23, 2006 Share Posted August 23, 2006 $660 from JustJap Link to comment https://www.sau.com.au/forums/topic/131374-power-fc-and-avc-r/#findComment-2431293 Share on other sites More sharing options...
paulr33 Posted August 23, 2006 Share Posted August 23, 2006 powerfc $900 powerfc boost kit $350 avcr $650 sell the avcr if you already have it and buy the powerfc boost kit. it works the same, uses the same parts and offeres the same control via the hand controller. it does NOT have gear judge however Link to comment https://www.sau.com.au/forums/topic/131374-power-fc-and-avc-r/#findComment-2431671 Share on other sites More sharing options...
thrtytwo Posted August 23, 2006 Share Posted August 23, 2006 powerfc $900powerfc boost kit $350 avcr $650 sell the avcr if you already have it and buy the powerfc boost kit. it works the same, uses the same parts and offeres the same control via the hand controller. it does NOT have gear judge however powerFC for $900 :S ? where ??? Link to comment https://www.sau.com.au/forums/topic/131374-power-fc-and-avc-r/#findComment-2432018 Share on other sites More sharing options...
paulr33 Posted August 23, 2006 Share Posted August 23, 2006 ER34 Skyline 414-AN008 AU $ 922.93 Nissan Skyline ECR33 RB25DET (For Version 1&2) 414-AN012 AU $ 922.93 http://www.nengun.com electronics -> powerfc Link to comment https://www.sau.com.au/forums/topic/131374-power-fc-and-avc-r/#findComment-2432039 Share on other sites More sharing options...
