help,.....i was driving first time my new bought R33 GTR....to another city, about 400km, when i was driving i notice the turbo breathing when i change gears and the BOV valve....suddenly when i reach 200km, i observe i lost power,,, and i have already different sound coming from the engine when i push the accelerator and need for power...and i am having a hard time going up 2000rpm....so, i didn't push it hard because im afraid i could damage the engine...what could these be??? help...could these be my boost controller??? i don't know how to set my controller??help....
https://www.sau.com.au/forums/topic/131378-help-me-my-r33-gtr/
I might of had a similar problem to you a few months back. anyways heres the story
Just did GTR Cruise 2 and coming home fanging it with the other gtr's (Obvioulsy to the speed limit). On the highway i shifted down to 3rd and boosted it, it felt like the car had dick all power and made it sound like it was struggling for air. Initially I thought the Bov's were seized, hence blowing air out on boost. anyway i "baby'ed" my car home. After a few hours stopping at my girls house, i drove it home, nothing was wrong then, so i let it go without another care in the world.
A few weeks later i was boosting it hard in 2nd, to the h-way speed limit (hahaha), and poooooof!! car gets farked.
anyways to save the rest of the story, my pipe to the INTAKE of the cooler had popped off. seriously.
So at the end i think the loss in power was due to the failure of the worm clamp to the INTAKE side of the intercooler. I bought a new one and never had a problem again. So i think on the GTR Cruise is was loose and allowing air to bypass the cooler and hence loose power.
You shouldnt need a pipe diagram for your car, its pretty straight forward once you take off the front bar.
good luck, pm me if you still have the sh*ts.
Edited by arbess
I was removing all my spark plugs this morning and i found out that my 4 and 5 cyclinder plugs are black.... and the rest are brown....so, tomorrow i will try replacing them all with new...and i will also check the intercooler pipes....thanx guys...ill update you what will happen then...
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
