i just got my r33 back from having the water pump and timing belt replaced
now the car is making a whiny rattling noise that was never there before, its worse when its idling and just sounds like its running crap
was thinking maybe they did the tensioner too tight or something?
anyone got any ideas? and could i be doing any damage to the engine driving it like this? :(
https://www.sau.com.au/forums/topic/131393-just-replaced-timing-belt/
Theres not a lot to chose from for bearing noise, cambelt tensioners or alternator/powersteering pump/air con. You can rule out the latter by removing the appropriate belts and seeing if the noise is still there or by listening for bearing noise on each unit.
Chances are it is the cambelt tensioners if the cars done reasonable kms.
Before you got the belt replaced it would have been stretched making the load that is on the cambelt tensioners less and hiding any wear.
Now that you have a tight new belt and tensioners reset there will be more force on the bearings which will show up as a rattling noise if the bearings are on their way out.
And just to add, never had any probs with GATES belts, they make pretty good belts, Nissan don't make their own anyway.
Timing belt? Mine whined a little bit after replacing the idler, tensioner, and belt. (all stock replacements).
It might have been tight, but in the first month i'd imagine that the belt would slacken off a bit, and you'd have to retension it. Mine has smoothed out and is fine now (4 months since change).
Only other thing that comes to mind is if they didn't do the tensioner up properly... the belt will slap against the cover, and whine as it slips past the bearing.
Remove the top-half inspection plate, and check that the belts seem really tight.. maybe even shine a torch down there to check it.
is it like a high pitched noise? (like its there when u start it, and when u press a bit of gas or if ur stationery) if it is, then maybe the belts are a bit tight - I had the problem when mine was changed - its a quick fix 15 minute job
Take it back.
Did you get tensioner and idler changed when the timing belt was done?
It may be air-con tensioner bearings or others, but there should be no noises.
hmmm, well i bought the parts and only got a new belt, so id have to check that out..
Its probably a gates belt! ask them what kind they used. gates belts are crap! stick to genuine. That is if all your other cam gear is stock. who did it?
yeah all stock and mmm yes it is a gates racing belt, the blue one...
thanks for that, well its done 113000, so yeah will suss it out
You might have a baby caught in the belt, check under the timing cover for small fingers or toes.
LOL...quite the comedian
Hey! I saw your car at RE the other night when I went to pick up my car! Rays a good guy, he will fix up the problem.
hey, yeah he is, i actually asked about it after i started it up while i was still there and heard the noise, he said it should be fine and could last till next service, but yeah i just dont want my car sounding like that for the next 5000kms so id rather have it fixed, watever it is and yeah dunno wat to do yet
Sounds like the belt might just be a bit tight - its often the case with the new belts (im assuming here its the same problem that I had). It would die out in a couple of months - but it is quite embaressing driving a hot car when it makes a noise like that.
Edited by emsta2003
yep it is kinda high pitched (and very annoying) and its worse on idle/stationery and yeah my initial thought was its too tight...mite be easy but i cant fix it myself though cos i have no idea wat im doing lol
i had a look and the belts are like super tight, i cant twist them at all
if its to tight (very common mistake) it makes a wir wir wir wir noise
if its to loose it makes a flap flap flap noise.
the belt tension adjustment needs to be as follows.
with the belt on and the tensioner not done up...wind the motor over to take up the slack in the belt. then simply lock off the tensioner. (thats what the spring is for lol :) )
hope that helps :)
Sounds like what I had after my timing belt was changed - its a 10-15 min job. Main thing is its nothing serious
if its just loosening the belt a bit, it can be done without having to remove the whole front. There is a cover underneath the car which has to be removed (can be done while the car is on the hoist), then its just a matter of using a spanner or socket spanner to adjust the belt.
Well, thats what happened to mine anyway...and there hasnt been any troubles so far...
I think your confusing the aircon belt with the timing belt, or at least one of the other two that run off the harmonic damper. The timing belt is located behind the timing covers which do need to be removed inorder to adjust the one tensioner which is also behind the covers.
The only idler that can whine/wir/squeel is the aircon idler which is obviously outside of the covers and sits below the aircon compressor.
and whoever said gates belts are shit is a moron :(
Edited by r33_racer
Ah - that might be it - yeah they didnt remove anything when they readjusted the tension..:(
  • 1 year later...
k gates racing timing belt does make noise but when mine got done it was found that 2 days later somewhere i have a dry bearing when it starts up it make a really scary grinding noise then goes no probs after 2 secs but as it off the road no big worries atm being fixed soon and yeah they "rigoli" over tension the belt
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Right, here's a video of the basic operation at least.  This is what you can expect day to day when you turn the car on and it boots from standby.  The only thing from a media point of view I haven't gotten working is for it to autoplay plexamp when it turns on from standby (it works from cold boot) but that's more of a plexamp problem as it will autoplay other music players.  Also attached is my one stray cable.  It's part of the screen's wiring adapters but there's just nowhere for it to go in my car.  I've just now done a bit of research and found a matching port on a 2010-2014 head unit with BOSE.  Mine has no BOSE so that's that case pretty much closed I think.  Plugging in the Infiniti AC panel basically did nothing for me, so that's a dead end as well.  Next port of call is to mess with this CANBUS module and see what I can find from it.  I found this resource containing the DBC files for a 2010+ G37 : https://github.com/icecube45/Dash_InfinitiG37/blob/master/InfinitiG37.dbc I'll now have something to go from when I try to extract my CANBUS data so I can see if the HVAC Mode, Fan Speed, Temperature, etc. match and also the gear shifter position.  It's a pretty big assumption that it's just mismatched CAN signals but considering all the devices in the CAN network are talking to each other (AC can be fully adjusted just with no info on screen) it might be a safe one.  I will report back WhatsApp Video 2025-02-26 at 12.49.10.mp4
    • Thanks for that Paul.  Do you think if I posted a picture you'd be able to remember where it went?
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • As above, you did refill the coolant and burp the system before running it again didn't you?
