hi there
i tried a search - stagea nooB :( also
just trying to cover all areas before buying one of these - waiting for a reply on ins.. and now compliance
i think i've heard/read that there's a couple of places in QLD that do it... But i'm in SA, does anyone do it here?
thanks
-Matt
call J-spec dude! They have come through with flying colours for me so far, even when the sh+t hit the fan man they went above and beyond their usual obligation which I'm stoked about. From purchase to freight and compliance they'll do the lot for ya.
I have used different brokers before so I have others to draw a comparison with.
https://www.sau.com.au/forums/topic/131419-compliance/#findComment-2432009
thanks guys - i called up PVP imports today in SA - they are 'looking into' the compliance thing for stagea in SA .
i have an importer lined up who i will get a great deal from - just need a compliance person, looks like QLD is the go. is there a website to any compliance people
also thanks for the heads up SK
https://www.sau.com.au/forums/topic/131419-compliance/#findComment-2433767
Who ever you choose, make sure you consider a few things
Has you car got any mods, minor or major?
If yes, then you are going to need to borrow stock parts to comply
Some workshops have parts, others do not.
Like wheels, suspension, exhaust etc which are common bits
Your compliance bill can go thru the roof if you need to buy these parts if your workshop does not have these parts.
Ask the shop before you agree to use them and what they will charge to use and fit and remove these parts.
I have used Phil White from IAMSHE on the Gold Coast twice now with great results.
https://www.sau.com.au/forums/topic/131419-compliance/#findComment-2433996
pvp complied my ceffy for me - but prices got a little ridiculous to say the least - but if it all summed up that they were cheaper that sending it interstate it may've been an option
will definitely have to do some research with the compliance people
do people have contact details for
-Phil White from IAMSHE
thanks
https://www.sau.com.au/forums/topic/131419-compliance/#findComment-2435391
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
