Hey guys and girls,
I have noticed that my coolant gets very low, I fill it to max and the next day it is right down, but stays at that level...
What could this problem be??? Is it a blown headgasket??? If so how much will it cost for me to replace and what should I get if i will be running a t3/t4 turbo (or something like that - one that is for mid range grunt)???
Cheers,
Clakka
https://www.sau.com.au/forums/topic/131421-leaking-coolant/
Hey guys and girls,
Cheers,
Clakka
are you talking about the overflow bottle near the battery?
if so, then you might want to check the actual radiator instead, more than likely when your filling the overflow up when cold, the fluid expands and is pushing it out of the overflow at the top of the bottle
doubt your gasket is gone if above is true
around $330 for a cometic gasket, plus install labour
will handle whatever you through at it
https://www.sau.com.au/forums/topic/131421-leaking-coolant/#findComment-2432094
You are forgetting the block o'ringing and the sealant. There's another $300 worth.
And a metal head gasket doesn't seal as effectively as a standard one.
ok so sealant is like $40
no O-ringing required ..
mine wasn't done
https://www.sau.com.au/forums/topic/131421-leaking-coolant/#findComment-2432614
Check for water leaks around the water pump, they have a little hole in them that indicates when they are corroded, they then leak from this hole. Much better than having no indication and sending the fan through the radiator.
If thats not it check all little hoses under the manifold and the little one that runs around the back of the head (drivers side).
I highly doubt its a headgasket or what not.
https://www.sau.com.au/forums/topic/131421-leaking-coolant/#findComment-2432617
Do they run that viton coating on the Cometic gaskets now? A few years back they were just a straight SS layered gasket.
im thinking they do. as far as i have seen they are single use items, which supports the coating idea.
from cometic website FAQ - http://www.cometic.com/faq.aspx
Why does Cometic recommend MLS gaskets to be installed dry?
Cometic Multi-Layer Steel (MLS) head gaskets go on dry because they are coated with a sealant. Each MLS head gasket is coated with a .001" thick viton rubber that is bonded to the outer stainless steel layers. Adding an additional sealer can hinder the performance of an MLS head gasket.
https://www.sau.com.au/forums/topic/131421-leaking-coolant/#findComment-2432655
mmm, true.
https://www.sau.com.au/forums/topic/131421-leaking-coolant/#findComment-2432659
I run one on mine, had it fitted ~2yrs ago.
They do have a rubber type coating on them and it specifically states not to use any coating sprays.
Mines sealed well with no issues, daily driven, lots of short trips so its seen thousands of heat cycles.
https://www.sau.com.au/forums/topic/131421-leaking-coolant/#findComment-2432690
    • I'm hoping I just don't have to do an engine rebuild NOW. Doesn't mean I won't do it at some point. I think a plus point is that the car presumably ran on or close to stock power nearly all it's life so far. Only the Owner I bought it from actually increased power with a standalone ECU and blew the OEM turbos. And after it got thee 2860s it wasn't driven an awful lot either.   That is what I meant. With the twins coming on so late (4500-5000rpm) I hope the rods won't want to exit the block prematurely. And it still being a 26 means the torque curve isn't gonna hike up all that much.   It didn't blow up on the dyno when they tuned it to 500ish crank. So I suppose it'll be okay for now. They did put a Tomei head gasket on first though which did not seal at all, and they redid it with a Cometic one. Which I hope won't be my water leak.   Mainly anything oil. So far all it has is the N1 pump, oil restrictor and a filter relocation kit with a cooler.
    • 15000? ish? Something like that anyway. It wasn;t so much a wear as a tear that then spread. Might have lasted a lot longer if not bothered by just one incident, whatever it was. I took a punt. They are really comfortable and do a good job of holding. My daughter HATED it when I first put them in, and probably still does now. She has sensory issues and hates the way they are all up your business. I'm 197cm and 95kg. Not fat or particularly wide, and the XL size seat is the rigth fit. If I was any fatter it would start to get too snug. Any skinnier and you'd possibly want the smaller width.
    • Mrs rs focus came factory with recaro cs  sportsters in it and they a pain in the ass to get in and out of with the really high bolsters, once you were in them they were one of the most comfortable seats I have ever sat in
    • The NA 2.5 has very little torque. You won't feel much. Those trannies are also a million years old now and it could well be f**ked. First generation electronically controlled autos will often refuse to kick down, ete, etc, depending on what's wrong with them.
    • Yes, but no but yes but no. Those "it's fine up to 500HP" rules and everything else like it were all determined back when the cars were 10 years old. As they are now 30 years old.....what do you reckon the chances of something shitting the bed are? I'd say they are much higher now than they used to be. You might be lucky. You might be unlucky. Spin the wheel and find out. Yeah, nah. It's actually exactly the opposite. Making boost early and having heaps of torque able to be generated right in the middle of the rev range will do more to damage an engine than having to rev it high to make the power. Think about the load on the conrods, bearings, etc, to make 400HP at 4000 rpm, vs 400 HP at 6500 rpm. So someone has already "let the Nissan out" which is how we describe the increased chance of a fiddled with engine to have had something done wrongly. Many more engines that have been opened die than stock ones do - even if you into consideration how they are treated wrt power levels and the like. Again, not saying that yours will definitely have been put back together by a moron. But the possibility does exist. It's still a lottery. Spin the wheel. What weakspots?
