Hey guys and girls,
I have noticed that my coolant gets very low, I fill it to max and the next day it is right down, but stays at that level...
What could this problem be??? Is it a blown headgasket??? If so how much will it cost for me to replace and what should I get if i will be running a t3/t4 turbo (or something like that - one that is for mid range grunt)???
Cheers,
Clakka
https://www.sau.com.au/forums/topic/131421-leaking-coolant/
  clakka said:
Hey guys and girls,
Cheers,
Clakka
are you talking about the overflow bottle near the battery?
if so, then you might want to check the actual radiator instead, more than likely when your filling the overflow up when cold, the fluid expands and is pushing it out of the overflow at the top of the bottle
doubt your gasket is gone if above is true
around $330 for a cometic gasket, plus install labour
will handle whatever you through at it
https://www.sau.com.au/forums/topic/131421-leaking-coolant/#findComment-2432094
  3lit3 32 said:
You are forgetting the block o'ringing and the sealant. There's another $300 worth.
And a metal head gasket doesn't seal as effectively as a standard one.
ok so sealant is like $40
no O-ringing required ..
mine wasn't done
https://www.sau.com.au/forums/topic/131421-leaking-coolant/#findComment-2432614
Check for water leaks around the water pump, they have a little hole in them that indicates when they are corroded, they then leak from this hole. Much better than having no indication and sending the fan through the radiator.
If thats not it check all little hoses under the manifold and the little one that runs around the back of the head (drivers side).
I highly doubt its a headgasket or what not.
https://www.sau.com.au/forums/topic/131421-leaking-coolant/#findComment-2432617
  3lit3 32 said:
Do they run that viton coating on the Cometic gaskets now? A few years back they were just a straight SS layered gasket.
im thinking they do. as far as i have seen they are single use items, which supports the coating idea.
from cometic website FAQ - http://www.cometic.com/faq.aspx
Why does Cometic recommend MLS gaskets to be installed dry?
Cometic Multi-Layer Steel (MLS) head gaskets go on dry because they are coated with a sealant. Each MLS head gasket is coated with a .001" thick viton rubber that is bonded to the outer stainless steel layers. Adding an additional sealer can hinder the performance of an MLS head gasket.
https://www.sau.com.au/forums/topic/131421-leaking-coolant/#findComment-2432655
mmm, true.
https://www.sau.com.au/forums/topic/131421-leaking-coolant/#findComment-2432659
I run one on mine, had it fitted ~2yrs ago.
They do have a rubber type coating on them and it specifically states not to use any coating sprays.
Mines sealed well with no issues, daily driven, lots of short trips so its seen thousands of heat cycles.
https://www.sau.com.au/forums/topic/131421-leaking-coolant/#findComment-2432690
