Just thought I'd pop up a post to counter the inevitable sniping that is happening after our dyno results at Autosalon. The Dyno was run in Shootout Mode which means that all variables and adjustments are locked. 2 other cars (B REAL and Leslie's MX5) ran within 1 or 2% of what they made on SSTs dyno during the week. Bear in mind that figures touted by other tuners for their cars from previous "Salons" were not run in shootout mode and are subject to interpretation.
Jash
https://www.sau.com.au/forums/topic/13143-auto-salon-dyno-results/
Jash,
I read all the post's in here and I don't think anyone has has a bad thing to say about the result. In fact all of us there were very impressed, even old Jaffey:D
We only have a go at the fact that you can only run 12sec with a 649rwhp car:p
I agree, the dyno results were very close to Steve's dyno and congrats on winning.
See'ya:burnout:
Oh it may not be anyone in here, I just wanted to assure everyone in here that the results were legit, as per usual in Perth there's always someone reckoning we fudged the result.
Hey it was a poorly tuned 500rwhp car when it ran a 12 at 123. something mph :shake: . Will all be fixed with a Holly or some PPG gears and some Nittos.
Jash
Jash,
We know the car should be capable of much more at the plex, and we want to see a GTR take it to some of the V8 brigade.
WE will only bag you if you deserve it:D How much boost were you running, and is there anymore left in the engine at the moment?
See'ya:burnout:
Quite a bit left in it based on how its going now. We just started using VP103 in it and we reckon that there is at least 500rwkw in it. We we're running 1.7 bar which is getting towards the meat of the efficiency for the 3037S. We'll see. Now I've just got to find a Holly sequential for the right money...
Jash
The Dyno was even closer than that, BREAL and MX52NV made within 0.3%.
The runs were in shootout mode and for real.
So that is the highest figure in WA for a GTR and would be 734rwhp at Myaree and upto 800+ on the dynopack and dynojet
dynos. Good on ya Jash for outrite and Paul for the 4cyl crown.
Lets make Shootout mode STD for Shootouts to stop the fudged
figures that DO happen.
Dude,
Ta Dude, nice to meet you all finally - met PVA too.
I'm a sucker for anything with Sparco on it. I also want one of those Superfun Happy baseball bats - I reckon it'd be hilarious to kneecap an intruder with one.
Jash
Amen Hippie,
Shootout Mode is made for a reason and comes with every Dyno Dynamics dyno, if an operator says they havent got it then they are telling porkies. Also worth getting any power runs done in Shootout mode so you can compare with some degree of accuracy.
Jash
Nice work jashy, be nice to see that thing at full boost and power finally, it sat in the shop waiting long enough for it to happen..
bring on the 1k mark and maybe perths first 9 second 4wd pass, might give the eastern states boys something to think about..
    • And also there were for sale scams and the like. For sale posts need piccies, and not having piccies makes it harder to do a driveby scam.
    • And I forgot to add my *** footnote to the above post, which was that the pipework mods would be even more significant than what had to be done for the highflow. So just add that onto the list. Pipework mods are no killer, just made the tasklist longer at a time when extra tasks were not welcome.
    • I mean he could post them to imgur or the like and create a link. But yeah, spam bots absolutely will post pictures in their first posts.
    • Ah ok, reason I asked was for the sake of not having to upgrade everything if the turbo couldn't be capped.
    • pffft! My alignments are starting to take 3-4 weeks each. Bugger overnight - that would be a dream! Overnight is when I leave it on stands with the rear suspension in pieces, hoping I can remember where I was at when I come back to it. I have to set the car up on a level surface so I can get decent camber measurements, then try to set the RUCAs to the right length to get that right. Then I have to put the car somewhere else where I have enough room to set up the bumpsteer gauge (laser, paper, mirror), so I can dial out that. Then I need to go measure camber again because changing the tension arm length affects that also. Then I need to measure toe, and I can't do that to my own satisfaction at home, so I have to put it on an actual aligner. Then I have to go back and fix the camber again, and if that took more than a half a turn, decide if I want to set up the bumpsteer measurements again. I previously had the bumpsteer almost completely banished and then I started changing things again! And that's only the rear end. Not even gotten to talking about the front yet. And this has been going on in the context of me discovering a seized bolt in the LHR FUCA bush at the upright, hence needing total disassembly to replace that bush and the others that were not far away from the same outcome, replacing sphericals in the front end and making a mistake that resulted in needing to do it again, which is only half done right now. It's a selfmade nightmare. Only have self to blame, etc etc. But regardless, I am so complelely unable to utilise the services of a normal wheel aligner that I have no choice. I haven't found a shop in my city that does "race" alignments - and by that I don't mean I want my car to be set up for racing, but the set of adjustments that I have available and that need to be used to do the alignment are the same as you'd find on a race car. I haven't looked everywhere, but there doesn't appear to be the equivalent of the motorsport focused shops that are present in Sydney and Melbourne. And such an alignment would cost $300, and you only want to do it once in a while, and you don't want to find out that you have to replace bushes and bearings and such while you are spending that $300 so you have to come back and spend it again a week later. So I stay living in my self made nightmare for the moment.
