Hey guys,
I have a just jap front mount intercooler and was wondering what piping kit thats are available that will allow the intercooler to sit back far enough that the piping wont stick out the bottom of the m-spec front bumper. I purchased piping for it and installed it on the weekend and after cutting a considerable amount of my front bar and installing the intercooler i realised that i wasnt going to be able to make it fit properly and it stuck out the bottom of the bar terribly. This afternoon i changed back to my sidemount cooler untill i could find more appropriate piping to mount the cooler without piping sticking out and making my car defectable.
Any help would be greatly appreciated in highlighting what piping kit would be suitable.
Kind Regards,
Daniel
Attatched is a picture of the cooler installed with the piping i purchased.
https://www.sau.com.au/forums/topic/131434-intercooler-install-r33-mspec-1993/
Mine is about the same - I noticed you dont have your lights hooked up.
I had the same problem - what i ended up doing is cutting into the light with a air saw. when you cut into the light be carefull you dont cut too much - inside the casing the light is still sealed and i was able to tape it up and fit the light in.
bad thing is that the lights stoped working shortly after but the blinkers still work and it looks complete so i guess thats all good. i think the lights blew because i did not secure the light inside much - try packing it with something and taping it a bit more secure or plastic weld it up and it might work fine for you.
as for the piping - mine can be seen from the front but it does not stick out the front bar so i never worried about it.
Hey guys,
Kind Regards,
Daniel
hey man, from that pic it looks like you placed the intercooler too far forward so its hitting your blinkers
The kit comes with metal brackets that attach to the reo bar and also under the cooler to the car chassis, this allows the cooler to be installed closer to the radiator
It looks like you attached it straight under the reo bar
Unfortunately the pipes i purchased run through the standard pipes on the right and then behind the intercooler. Thus making it impossible to mount it back further. They were custom made and unfortunately poorly made. I have put my sidemount back in for now.
I dont want to have similiar issues with new piping that ill need so i was hoping someone could point out a more appropriate kit that wont give me the same issues i had with my front bar ect.
Thanks for the feedback so far,
Dan
ive got the same problem. i wish it sat a bit further back.
i had to cut alot off my bar off :)
you could get your pipes cut to let it sit further back. if they're aluminium go to an aluminium welder and they'll be able to help you out.
get some strong, thin metal and cut out brackets for your core to sit further back.
    • Just a thought, but instead of restricting, is it possible to do like an "up for review" kind of thing? Where say someone who's not an admin/mod tags, it would require approval for it to actually tag? User posts with a 'tag' > Admin/Mod Reviews > Approves tag > Tag now exists kinda thing? Just came across this thread so Im not too sure if Im straying off topic or not but forgive me if i am...
    • Yes, a plan for non-action is always my first sort of plan! I'm happy to see what falls out of invision's update. I had been having some thoughts on what to do with this the other day and they all seem to have fled my memory, after various solar panel induced traumas, squeaking suspension sphericals, etc etc, over the last little bit. I'll try and recall what I had in mind and make sure that I put it into print in some form before the Alzheimer's strikes again.
    • The ability to have both a 5500 stall for launching, and a regular lockup for every other scenario is pretty sweet. Does it actually work well like that though in the real world? Would it hold up to track use and otherwise you'd never know you had a stall converter in it? If so, that's awesome
    • The thing is, once the content has been tagged we can chop and change the end result as much as we want. Its identifying the content in the first place that needs to be done regardless of the final outcome.
    • Sorry @GTSBoy I thought I'd replied here. There's a new BIG version of invision coming out soon, it might be worth waiting until that happens as it contains a lot of improved functionality for tags. My suggestion would be to add a top level page (not thread) with some info on it and then link to sub pages for various topics. We could even just start really simple with 2 or 3 pages underneath it. Those pages could just have a view (like a pre configured search result) of the tags we choose to put on it. We could have some background or an intro on each of these pages. My only issue is that while admins and mods can update the existing content to contain the tags we want, new posts can have whatever tags the author wants. That said, the reason our tags are so messy is because of that, so maybe we restrict tagging to admins/mods in edits.
