Just bought a set of hks 600cc injectors for my rb20 and they came off a gtr. I know that gtr injectors need a ballast resistor for them to run on a rb20 but ive checked nengun and the part numbers are the same for both gtr and gts-t 600cc injectors; does this mean they are a direct fit?
Cheers.
https://www.sau.com.au/forums/topic/131451-injectors/
Both are top feed injectors but RB20 are high impedence and RB26 use low impedence injectors.
You should have to use a resistor pack of some sort to work out tthe impedence difference between the two.
Search for injectors on here, there is a thread telling you how to make your own resistor pack.
https://www.sau.com.au/forums/topic/131451-injectors/#findComment-2436104
