Hi Guys, I am having a little issue with my idle still. I have replaced my O2 sensor, cleaned and resoldered my AFM, Cleaned my ACC Valve and reset my ECU.
The problem is that it idles at 1500-2000rpm for about 5secs and then drops down to normal! It is an RB20det in an R32 GTS-t. I have quite a few mods but don't think that is relevent at this stage.
Resetting the ECU has fixed the problem before but it came back the other day after a big drive (400KM).
I am happy to reset it again, but I am guessing it will continue to occur and due to it fixing itself after a reset it should be electrical and I think it would be worth checking the ECU for error codes and might be able to narrow it down.
I have had a look but I have not found anything conclusive.
Can someone instruct me how to check for codes (is it a light that flashes a certain number of times and that number corresponds with a particular fault?) and could someone post up a list of the codes and their meanings? Any other help would be great!!
I have also read about a consult cable that connects to your notebook... This could be good, would this be a better option?
If I am able to get all the info it could be an idea to add it to the FAQ sticky.
Thanks guys!!
Todd
https://www.sau.com.au/forums/topic/131475-ecu-error-codes/
ahhh how friggin retarded is the search on this site, never any decent results zzZzz
http://members.iinet.net.au/~robi/public_h...skylinebook.pdf
Check that out its very handy, i think about page 30 has the instructions and codes and LED patterns
Edited by r32 gts-turbo
https://www.sau.com.au/forums/topic/131475-ecu-error-codes/#findComment-2434764
newkleer has a consult/lcd which displays the error/fault codes and can also reset them ... check it out ...
http://www.skylinesaustralia.com/forums/in...howtopic=130985
do you mean that your car does this upon start up ...
i had the same prob i was told to reset the ecu and then turn the car on and let it idle to operating temp ... then hold the revs at 2000 rpm exactly until the car makes this noise bout a min or so ... let the car idle for 30 secs then turn it off ....
leave it to cool turn it back on and see if the prob is still there :ninja:
its only on a cold start isnt it?
https://www.sau.com.au/forums/topic/131475-ecu-error-codes/#findComment-2434836
WICKED! Thanks for that!!
I already had this somewhere but didn't think about it!! I have now printed it out so I won't forget to check it first next time!!
https://www.sau.com.au/forums/topic/131475-ecu-error-codes/#findComment-2435650
The problem happens ALL the time. Not just when cold or first starting.
I can drive solid for an hour and stop at the lights and it will idle at 1500-2000rpm.
This is most anoying when in traffic and you are bumping along at low revs but every time you put your foot on the clutch it jumps up.
https://www.sau.com.au/forums/topic/131475-ecu-error-codes/#findComment-2435982
I got the same problem
i've checked freakin everything, changed the afm (fixed it for like 1 month) then problem came back
new spark plugs service and everything
afr's and stuff are on the spot, car runs mint
but doesn't idle so well
let me know if you fix it
Cheers
https://www.sau.com.au/forums/topic/131475-ecu-error-codes/#findComment-2436366
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
