I had a guy do this to me, he was in a short wheel-base patrol. He sat behind me with his lights right in my face, i tapped the brakes and he freaked out because he was so close to me. He then overtakes me, sits in front of me and turns on some spot lights he has facing backwards! I couldn't believe how anal this guy was. Luckily I wasn't on that road (M2) for too long so I left him to think he's the most important person in the world.
  • Replies 668
Posted Images
What is it with people that just constantily just follow someone? is it so they don't have to concerntrate as much? I personally wished I was the only one of the road and focus on the actualy white lines rather than another car.
anyway, end rant. at least this weekend i'm staying in Canberra.
They just want you to protect them from the roos.
Here's a couple of things that ticked me off today...
1. Cyclists that sit in the left hand turn lane at a set of traffic lights when they are actually going straight ahead and you want to turn left THEY DON'T MOVE even when they do hear your woooooopachew of frustration!
2. Having only just walked into a shopping centre and stepped on to an escalator and get some guy in his 40's looking down my top from the top of the other escalator then wolf whistling at me as he goes past me! :wave:
I mean, what does a girl have to do these days... Walk around in something that covers you from head to toe and a brown paper bag with eye hole slits? lol :(
That's my b!tch for the day :wave:
Your doing a public service by letting him look down your top though, it was part of a study that a couple minutes a day perving can increase a mans life span by as much as 10 years. Its true, i saw it on the internet.
Also, females void any comment about male perving if she wears:
tight jeans
tube top
no top
short shorts
basically any figure hugging piece of clothing, if you dont want people to ogle dont advertise it. Of course, don't let this put you off wearing those clothes though :wave:
Edited by Baconer
tight jeans
tube top
no top
short shorts
basically any figure hugging piece of clothing, if you dont want people to ogle dont advertise it. Of course, don't let this put you off wearing those clothes though :D
motion carried! :)
tight jeans
tube top
no top
short shorts
basically any figure hugging piece of clothing, if you dont want people to ogle dont advertise it. Of course, don't let this put you off wearing those clothes though :)
No way man , a chick should be able to were what ever they want without getting hassled , i think 99% of girls don`t mind being looked at as long as they don`t get rude comments
Pretty sure it's meant to be humerous there Angus.
EDIT: Actually one thing that peeves me is the Skyline drivers who are too cool to wave when they can clearly see you in your Skyline waving. Fkn tossers.
Edited by MIVEC
OK sorry i didnt pick the sarcism in Baconer voice i will just shut up now
most skyline driver are 2 cool to wave the only ppl who wave at me are on here
What really ticks me of is people who sign up to forums just because someone who is ignoring them as they don't want anything to do with the just to harrass them ACTLUDA this is a public forum for discussions not for harrassment ok Jason (ACTLUDA) :rant::domokun: Now either use it properly or Get off it and take you prelude else where Stop Harrassing this person
Edited by SL33PR
WTF?
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
