You know, I was waiting for you to kick in with your thoughts, LOL! A voice of experience when it comes to turbos, yes?!?
Yeah, well I have popped a couple of turbos in my time...
Had to do a lot of research into which turbo I should get next (so that I dont pop another one) :P
  • Replies 668
Posted Images
Ooh, ooh: go HKS, GO HKS!!
So when do we get to see the white pearl beast again??
I'm off to check the Lotto ticket again today, LOL!
There will be very gradual forward progress over the next 6 months, then hopefully a flurry of activity that might, MIGHT see her surface somewhere at the end of '09. Unless the ticket comes in, in which case it'll be six weeks!! Believe me, and I know you're feelin' my pain, when I say it breaks my heart to see her sitting still. I keep telling myself "It WILL be worth the wait, it WILL be worth the wait, it WILL be worth the wait..."
i have a white pearl car.. are you refering to me?
if so i dont know when it will be on the road
Jeez, I hope you're not in the predicament I'm in with my pearl white one!!
Hmmm, back on the topic of inlet pressure, wouldn't it be somewhat beneficial to have a little bit of air left behind just at the front of the throttle body so as to increase response for the next time you step on the gas?
Or does it dissipate so quickly that it's better to vent and then just get freshly compressed (and hopefully cool!) from outside again?
well i think mine is minor compared to yours, the plug leading to the ECU just needed rewiring.. then a tune etc.. should be tomorrow but there are no garantees
I'll swap you situations, LOL! Still when 'little mischief' comes back to life, it will be a happy day!!
Good question.
There is always a certain amount of pressure in the inlet whenever the engine is running, as the turbo never actually comes to a complete stop, BOV's have a spring (which is usually manually adjustable in aftermarket items) which will only let a certain amount of pressure out of the inlet and keep a certain amount in.
If there was 0 pressure or a vaccum in the inlet, the next time you stepped on the throttle the engine would almost always stall.
Ok back on topic, what ticks me off is F_cking kids on school holidays with nothing better to do that run around egging houses!!! :blush:
Last night I spent half an hour washing 3 eggs off the back of my house and when I went looking for the little sh_ts I managed to catch them in the act but one had his 'P's and they took off in a POS Ford Laser before I could bash their skulls in!!
I called the cops and lodged a report and all they said was "we'll keep an eye out for the car, call us back if it happens again"... I used to like living in my suburb but now its full of little 16 - 17 year old f_ckwits!! :bunny:
what ticks me off is trying to sorce parts for my skyline and no one seems to have the items i need to clear my defect not even aftermarket ones
also motor bikes who ride down the middle of trafic that is moving at pace why cant they wait like everyone else
    • A few more recent pics
    • full send the cnut, do this   fark the wrapping and/or stick on siet. These guys are the ones to go to: https://www.realthermo.com.au/
    • Just had a look, they don't. Fuelling on the base map is purely alpha-N, and the ignition table is MAP. Remember it's just a base map to get the car moving
    • Hi everyone, I’m Dave from Canberra. Here's a few pics of my 1992 R32 GTST coupe which I imported back in 2006. Only mods so far are HKS Hi-power cat back exhaust, K&N filter, ATC Volanti steering wheel, Pioneer stereo, amp and sub. This was my daily driver up until 2015 and sadly hasn’t been driven at all in the last 5 years due to marriage, work, and kids taking up most of my time and spare cash.As such its in need of a bit of TLC and one of my goals for this year is to get it back to running condition and maybe look into club/historic rego. I’ve joined SAU so I can ask a few questions along the way (although I promise to google Current Problem +SAU beforehand!)
    • From talking to the mx5 guys the NC doesn't actually need bonnet vents like the earlier NA and NB models, due to a better designed cooling system and undertray design There's plenty of them used as street cars and weekend track toys running anywhere from around 170 to 250kw with stock non vented bonnets, I initially was going to get some bonnet vents, but, as they are not actually required, I'll put vents on hold for a while and just monitor temps, though I do need to get something to actually monitor engine oil temps though, coolant temp can be pulled from the OBD2, but the oil gauge in the car is not actual oil temp, it is only a calculation based off coolant temp and RPM ☹️ They do recommend upgrading the radiator, which I have already done with a triple pass, and the only other thing they recommend for a street car is heat management, like I talked about above to protect bits in the engine bay from radiant heat, and to either replace the nearly 20 year old plastic coolant expansion tank, which I have done, or get a aftermarket alloy jobbie for some bling They did also say that if I wanted to track the car on occasion a oil cooler and sump baffle would be required, and as I already have had a sump baffle installed when the engine was out......... I'm going to get a oil cooler with a thermostat....... just in case I do eventually track the car, but probably not, but still maybe...🤪
