WazR32GTSt
EXCELLENT IDEA!!!
Although, ....would it be possible to include what post number it is next to the user name in your layout?
EG:
rb25 - R33, R34, or Stagea
DYNO
255rwkw - Abo_Bob #9
220rwkw - 4door_sleeper #15
191rwkw - SECUR1TY #12
That way we can go straight to that post number rather than sifting through the whole thread trying to find what was done to that car/auto to achieve that figure....
cheers
P.S: Will post up my figures when i have em...
i could... but i personalyl think that would make it kind of confusing...
maybe after a while i could compile a list of the "best automatic mods" in the first post as most people are heading in the same direction with their modification route to achieve similar results
and on the not of results.. i had a new justjap intercooler and BATMBL split dump installed yesterday..
old setup was 3" bellmouth dump and small FMIC and was 155rwkw @ 14psi.. new setup made 170.4rwkw @ 13psi!!!!
and that's on the rb25 turbo!
R31 skyline, Rb30, Gt42 roller
378rwkw on 23psi, pump fuel
Mv automatics Re401RA trans
manual valve body
custom second gear hub
stage 2 shift kit
trans cooler
presently no 1/4 mile time as we have no track and i can't get
the auto to be reliable at the moment it is back at Mv's again
might be to much power for it, so you will have to look at the 300zx/patrol
box for over 300rwkw, or a powerglide/3 speed jatco etc maybe,
he is disecting it at the moment
cheers
darren
Guess i'll be the baseline...
142.1rwkw .... 11/1998 R34 - stock as a rock. Haven't run it on the track yet, they cancelled street meets at adelaide international raceway.
Edited by Howie
They are all anti auto fascist zionist cops!!!!
lol - picsorban !! :P
Gotta love the auto, I'll never go manual again. If only a PowerFc would work with the auto, if only.........
unfortunatly, ill always want to go manual.
i know how to drive an auto hard, trust me, but there is just something about a manual that does it for me.
i guess it could be that i can just cruise a long, 2nd gear, revs and pop cluch and out it comes!
i also find the manual is less hard on the brakes due to engine braking being more useful.
anyway, not to take away from the auto. for a 99% daily and 1% fun car, an auto is great! (too bad i seriously injured mine :P)
S1 R33 auto, 185rwkw with the following mods:
FMIC
3" exhaust from the turbo back (stock turbo)
AVCR at 10psi
Emanage blue (with only injector harness)
HKS pod with heat shield and CAI
Nismo FPR
Walbro fuel pump
Stock injectors
Stock auto transmission
I'll have to find the dyno sheet, will post up soon!
R33 (s1.5) with 203rwkw @ 12.5psi
(turbo & torque converter still stock)
Stage II shift kit
MV electronic shifter unit
Pro-ratchet shifter
Trans cooler
Power FC
EBC
Pod filter
Z32 AFM
FMIC
3.5" Turbo back
044 fuel pump
740cc 'overkill' injectors
Splitfire coils
Cam gear - exh
Oil cooler & thermostat
Havent run the 1/4 with current setup.
116000kms 1989 rb20det
rb25 standard turbo
3" dump-tip
R34 smic
standard airbox
S-AFC-1
RE4R01A(crappeiest of the crappest)
nothing but the outer case is originial.
2500rpm converter
165rwkw @ 12psi
very linear power curve(laggy)
PWR tranny cooler
Edited by RSTME
    • Just one more post to show the final result and the original "janky" solution for a laugh. Everything feels really tight and no wobbling at all, very pleased 🙂
    • After drying a few days, time to put her back together
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
