Waz; *politely* S-A-T-A-N-I-C ;) Cheers Bro!
666DAN; would've been more; just need a nice boost controller or someone who knows how to use the Hybrid EBC properly :) then I should be closer to Abo's number!
  • 1 month later...
thought i would list my mods since i have an auto r33
Hks frount mount intercooler
3inch turbo back exhaust with metal hi flow cat
GCG hi flow turbo 450hp
Greddy profec A boost controller
Apexi Safc 2
Apexi Sitc
Bosch 040 fuel pump
Sard Fuel regulator
hks cam gear (not currently installed)
Standard injectors
Z32 AFM
Stock transmission just with tranny cooler
Mv Auto Shift kit (in the process of buying)
I Have had the car for 4 years have considered converting to manual but i have alway's liked the auto. I got car tuned a couple of weeks ago and got 196kw at the wheels before i maxed out my stock AFM on 10.5 pounds. Last week bought a Z32 afm and retuned the car and made 229rwkw on 14psi. but now worried about the transmission since i have already blown one and don't want to kill another so i am hoping the shift kit should be able to cope with the power alright.
It is yet to be run will go to calder when the Mv valve body is in.
wife's daily driver..
s1 r33 4 door
rb25det
acl forged pistons
eagle rods
Jun crank collar
N1 oil pump
new nissan water pump
ARP main, big end, and head studs
full nissan gasket set including head gasket
standard head
standard plenum
standard coilpacks
stainless low mount manifold
gt3582r-iw
custom 3 inch dump
full 3 inch stainless system
ASE FMIC
sard FPR
bosch 044 intank
apexi power fc
q45 AFM
custom 4 inch intake
nismo 550cc injectors
current power is 317kws
with ignition advance average around 18 - 19 degrees
i have been advised that if i drop the boost to say 20 - 22 psi and increase the ignition advance to 21-22 degrees the power should head up towards 330 - 340, without to much pinging.
but thats yet to be proven on my set up.
standard trans
mv stage 2 shift kit
large trans cooler.
Very nice mate ! Are you ever going to have a play with it on the strip ? Would be cool to see what mph it pulls !
What afr's it running top end ?
its near level on 12 afr once on boost.
im planning on dropping that down to about 11.5 afr then pumping some more ignition advance into her.
Hey i would love to stretch her legs down the strip but we dont have one.
bloody government over here are slack, and private enterprise is even worse.
Glad I found this thread... I will add my Datsun 120Y that has a RB20DET auto
Engine has
20thou forgies
Walbro + Bosch 044 & surge tank
GTR ingectors
Stock AFM just before the throttle body
3" exhaust
Garrett GT35R 0.63 exhaust
38mm Turbonetics external gate
Auto has
MV shift kit
MV manual shift controller
B&M pro ratchet shifter
4200 stall converter
trans cooler
185 kw
I could only find my 13.1 @ 113 timeslip from yesterday but it has done a 12.9 @ 113.
Best 60 foot is a 2.25
I use 205x50x16 Toyo R1-R and a 3.7 lsd diff.
I have been told I have the incorrect type of muffler fitted and i need a straight through design.... Damn restrictive V8 muffs.
post-24062-1162824263.jpg post-24062-1162824293.jpg post-24062-1162824441.jpg
Edited by RB120WHY
    • If you really don't want to touch anything you can try to trigger off the timing loop just to see if it's sparking semi-regularly. Don't trust it for actual timing measurements.
    • Also replace the fuel filter aswell today
    • Hey everyone, I have a r34 GTT s1, im having a problem with my skyline, ive let the car sit in the garage for the last couple of months and havent run it and ive gone to fire her up today and it cranks but doesnt fire, i have been having problems with it previously where it wouldnt start again after driving it around for a bit. It use to start fine on cold start ups but if you drove to the petrol station and fueled it up and went to go start it again, it would just crank and not fire untill you let it rest for a few hours, the car doesn't over heat it sits perfectly in the middle while driving when warmed up. Im thinking this problem has caught up maybe and now it just wont start at all. The car runs on e85, ive checked the e85 seems to be fine. I can hear the fuel priming before you go to start it and checked all my fuses and relays. List of things I replaced today - New battery - New sparkplugs - New Coolant temp sensor I was thinking about testing the CAS but from what ive seen online, if the CAS is cooked, the car will actually start up but then die instantly? as mine just doesn't fire at all. Does anyone have any idea or have encountered the same problems? thanks
    • Modern reg stuff now, they'd have a wide input range which would push through a buck converter, it would need to be able to maintain voltage for cranking conditions (sub 9V at times). Likely runs something like an internal 6V rail, and then further voltage regulators depending on which circuit/area it is feeding. Modern voltage regs, like what I'm starting a new power supply design with at work, will let me run a 5V rail output, and as long as my input is equal to or greater than 5V, I have a 5V output. Except I'm not pushing a 5V rail in our system as I don't need one, we're setting up for a 3.8V rail. Our new design will allow me 6 to 60VDC input, and everything else doesn't care, even when I start pushing a few Amp outputs.   Realistically, the voltage drop off could be caused by a few things though, one could be literally the alternator is dieing, and hence charge power is dropping, which also means on a straight hard pull you're starting to send the battery flat... (Not that likely from a single couple of gear pull if the battery was fully charged). However, having earth issues, like stray earths not connected, or someone having put a ground loop in, will see the ECU appear to end up with lower voltage "input", mainly because the "ground" is no longer equivalent to battery negative. If they're comparing the input voltage using sensory ground for example, and sensor ground is what is in that ground loop, than the sensor output voltage will actually start to be reduced, when compared to battery ground... Yeah, ground wiring design can start to be a bitch... Also voltage going weird from inductive loads not being managed properly is another real bitch... Hence, why I asked above about how everything was wired in. If OP knows, and can post all of the actual connections from the ECU pin out, as well as what wires are joined where in the loom, which grounds from the ECU have ground points and where they are etc. Would help to see if there is a ground issue. The part I'd start with though, is putting a mechanical oil pressure gauge on to confirm the theory. Otherwise the next track day when the threshold is lowered could result in another of @Duncan favourite types of jokes... Knock knocks... Pretty sure this is what @GTSBoy is also self high fiving...  Is all great that we have a decent theory... But they need to prove it before relying on it...
    • When I worked at BlueScope Steel, we had an Ethernet network, with every switch setup with a duplicate switch. Even when looking at all the primary switches, they had duplicate links, there was then also duplicated links between the primary in section A, to the duplicate in section B. So for each location that had networking, there was 8 network links. This was all back around 2007. That setup caused sooooo many issues, as many of those links were fibre. The network guys ran everything with Spanning Tree Protocol. And then we had great joy... The FOC Transceivers were slowly dieing, but in an intermittent way. And a lot of the time as they started to die, they'd drop offline for about 30 seconds... Spanning Tree Protocol was requiring 45 seconds to "rewire" the network... And by the time it was mostly finished, it had to start again as the transceiver was back online... Queue entire production network being constantly spammed with the spanning tree protocol messages...   My god I do NOT miss working in huge environments like that!
