  • 4 weeks later...
Just a mini update. I have swapped out the 550cc nismos for a set of 740cc nismo's.
And the new LINK G4 Plugin has finally arrived and i installed it, with the aux cable as well for extra inputs. What a nice bit of gear.
I was previously running the LINK GTST Plugin, and this is so much better, finally all the features i want !
Throttle response is much better... something that was bothering me prior. Hopefully on dyno this saturday if its avail to me.
Still have to swap out the 040 bosch pump for a walbro. The bosch ran out of flow previously, so im going to try a genuine walbro to see how it goes. I measured the pump voltage first just to make sure the supply wasnt crook. (i have already earthed out the negative to bypass the switching). And volts were 13.6 odd.
I even pumped in 30 psi into the actuator to load the pump, and volts were stable.... so definately will change it this week.
Ok, stay tuned !
Gary
Got onto dyno this sat to have a play. Found a few weird things with timing with the New G4 Link .... still looking into them.. however, as much as i tried, i could only get 257 RWKW (1417 N.M in 2nd gear) ..... so HKS manifold and proper .63 Turbonetic housing didn't do much.... Shame.....
Still think i have a problem..... yet to check cam timing to verify 100% there not a tooth out etc, and also , test the TIP (turbine inlet pressure), and the HKS now has a threaded hole at the collector to measure it..... to glean if the housing is simply out of puff...
The other variable is the auto/histall..... but a few others have made more on a very similar auto ... abeilt with bigger turbo...
Im very tempted to try to swap in a stock converter for a run..... just see what happens.
Anyway, running on link's internal map now , so using the 2.5bar link map sensor plugged into old MAF wiring (as used in GTST LINK) , for a second GP Pressure sensor, just need to T it into the turbo outlet to check full cooler and piping loss. Did i mention i love the new link G4 ??? :P
Until next time !
Gary
Just cause i can switch it into snow mode and then put the t-bar in 2nd and it never jumps out of 2nd.... you can floor it happily and load up against dyno before a run.
Yes the torque is getting pretty extreme though..... although it doesnt spin on the dyno. ! Hops up on the roller pretty decently though.... i should get a video.
So wheelspin out of the way, its just falling over. Once i measure the TIP pressure i'll make a decision from there.
Will try to get to drags soon. Charters Towers 1/8 mile social meet is on in 2 weeks... but then i'll do a full quarter run and see if its improved from best run.
740's are at 73% duty cycle, at 11.8 AFR.
Oh, and intially it felt like crap on the street, however, its the only known problem with the Vipec/LINK G4 , in that with the autos, the factory applies +12v to the tps SWITCH (for auto comp), whereas the Vipec/G4 only puts 5V....
So auto comp thinks car is at idle always and changes very early, and takes a while to go to first once stopped.... ie stop sign might see you taking off in 2nd !! Manual shifting got it lighting tyres again.... will rewire that wire when i get a chance
Gary
Gary
Its very wierd that both our cars are behaving like this
I havent been back on the dyno since I have fixed a boost leak
and I was also wondering if maybe the timing is out from when I did my 100thou service
consult shows my base timing at 5deg at idle but i haven't been able to check the physical timing yet
I'll let you know if i find anything of course ! You going to towers ?
Where was the leak ? My pcv hose is split and needs replacing i noticed on sat.
Gary
Edited by Fastrotor
just on the hot side exit of the turbo at the 90deg bend
it was a bloody band clamp ,it had locked up on me and i thought it was really tight so i left it be
turns out it wasnt and was leaking pretty bad
which may explain why when we went from 14psi to 18 psi it would only go up by 2-4kws poor bloody turbo was working its ass of to make 18
it does drive different now with the boost fixed
way more responsive lol
Good stuff Pete. I am going to bung the inlet and pump in 20 psi and check for leaks also, as this could be happening to me also. Might go the reverse way and do the same for the exhaust.
Gary
Gary
Gary the magic brown plug fixes all
surely you have read my posts on the brown plug?
behind the drivers head light there are 3 eletrical plugs
when you disconect the brown one it locks the trans in 3rd.
so reverse onto the dyno, open bonnet, unplug brown connector, put in drive, and away you go in 3rd gear.
obviously it stalls up a bit cause your taking of in 3rd but it cant possibly kik back on you as its locked in.
so its easy to tune all the light load points as well.
:D
Darren
Ahh ok ... gee must have missed that one, either that or just forgot about it. I'll give it a shot next time im on there in a few weeks. I wonder how that affects the transmission line pressure at all ?
It makes sense as when researching the ecu (i built my own pcb to replace factory one) i did notice the 3rd shift is both outputs just off..... so hence why your trick works no doubt !
Thanks for the heads up, and yeah that will help with low down tuning.
Once i get my auto comp running, i'll just lock up the converter for low down.
Mike at MV reckons locking it once in 3rd is ok on strip..... so i guess on dyno wont hurt either...... be a good way to figure out how good/bad the converter efficiency is i reckon. Still im scared of smoking it !
thanks Darren
Gary
Hey i thought you were manual 2rismo !! Nice, welcome to the club ! Will go quicker as is just not hitting the limiter.
What 60' was it doing ? Dyno sheet ? Hows the responce with the 1.00 A/R ??
Gary
Edited by Fastrotor
Just a quick one... not sure about the autos on the R33 but definitely on the R34; tuning should be done through 1st, 2nd and 3rd to get it precise, not just in 3rd. This was the case with mine, we initially just tuned it in 3rd and there were issues when under WOT in 1st and 2nd, took it back and weeded it out.
It'll be quite a time consuming thing to do as in 1st and 2nd WOT, the revs build rather quickly - but it'll be worth it to achieve a solidly smooth graph.
Gary
No dyno sheet. Didn't bother to print one. I drove it off the line for the 11.7 so the sixty was a yawn-worthy 2.0 seconds. It weighed 3250lbs race weight so you can do the math if you like. The response of the 1.0 rear is fine with the big converter but there's a lot more to come.
Stan, technically gearing shouldn't make a difference.... probably just couldn't get into areas of map in 3rd, whereas 1st and second got there..... This is where locking the converter up in 3rd would allow you to get to all the areas a manual could, without the humungous torque trying to break straps and such!
2rismo,
Oh ok, thought the launch looked abit soft for a transbrake ! Have you done a 60' with the TB ?
Is the converter a lockup one ?
mine's going back in a week for more finetuning
poncams want setting up a little more, got the intake injector setup and controller to perhaps go in along with some guages
did my oil and sparkies yesterday but will get the shop to flush the coolant when undoing the drive shaft
then do some tuning in 2nd gear hold and 3rd gear brown fuse trick
if we put on the extra fueling Im expecting ~235kw, so we'll see soon.
2rismo,
The converter is a 4k-ish TCE that locks up when it can. :) i could only get a few psi on the footbrake so it tool till 60' to come on song. I have only had one pass on the transbrake and lets just say the radials didn't like it. Even letting it go at 8psi. More refinement is required.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Gotta admit, I love the 20b Cosmo.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
    • Every one has seemed to of have missed . . . . . . . The Mazda Cosmo . . . . . . what a MACHINE ! !
