After alot of reading I still have some questions, I have a R30 skyline with a Rb25det making 330kw at the wheels. I would rather a manualised auto for daily and drag use. Whats my options id rather a nissan box, not sure where to start.
Ur options as far as Nissan boxes go are:
Re4r01a (gtst box)
Re4r03a (300zx box stronger then 01a)
3 speed jatco (strongest of all the "Nissan" boxes)
Other boxes (although more then likely overkill)
Th400
C4
Powerglide (do not use a glide for a street car)
Research is half the fun with autos get googling :thumbsup:
Re4r01a (gtst box)
Th400
C4
Not saying it's a good idea (personally I reckon it'd be a bitch on fuel, plus no fun to drive) but from memory there's a QLD GTST, and one from Vic running powerglide transmissions. Both are daily driven. Not sure if there's any info on SAU, but could be worth a look.
What fully manualized auto options are out there with 4wd adaptors, I have a 260rs stagea, weight about 1650kgs
Re4ro3a built up can be supplied with a 4Wd adapter, that would be the most civilised if you can get a nice size lock up converter,
or glides and TH400's can be made with a 4WD adapter aswell, if you went all out..
cheers
darren
I have a B@M cooler with a thermo fan on my stagea in the guard, i also have another davies craig trans cooler behind the intercooler
that it goes through first, then goes to b@M, then returns to trans
cheers
darren
What trans temp does it run at...?
I am using a 30row engine oil cooler for mine. Trans temp hasnt gone above 60degrees while having some spirited driving.
Where's your sensor mounted Rob?
I have a 30 row on my trans also, I still see 80+ coming out of the converter, before the cooler. Obviously after the cooler is much lower. I wonder how much difference there is compared to at the the sump?
In the sump of the box.
I havent tried it on the transbrake as yet
With a temp gun aimed at the hot side of the cooler we saw 85 while loaded up on the foot brake for about 5 secs
Edited by WHITER33GTS-T
Re4r01a (gtst box)
Th400
C4
Go the powerglide.
Scotty you got a cheap spare cooler that would suit a 33?!
    • IMG_8641.mov     She doesn’t sound the best but starts with out using any gas now. I just ran some injector cleaner through her. started roughly the first time after adding it but gave it the beans slowly upto 4k, Must have cleaned a few cobwebs out. another step in the right direction for the sub
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
    • How much does the shifter move when the car is in gear with the engine off? If it is more than about 1cm you need to replace your shifter bush. Your shifts will just get crunchier, not faster, with a short shifter unless you also rebuild the whole box
