Not saying it's a good idea (personally I reckon it'd be a bitch on fuel, plus no fun to drive) but from memory there's a QLD GTST, and one from Vic running powerglide transmissions. Both are daily driven. Not sure if there's any info on SAU, but could be worth a look.
There is a marron gtst with plates H8 GRIP or something like that in qld that has a powerglide in it.
YouTube r33 powerglide it's the marron one
What trans temp does it run at...?
I am using a 30row engine oil cooler for mine. Trans temp hasnt gone above 60degrees while having some spirited driving.
f**k knows, its just the car to take kids to school ..i put them both in there as i had them sitting around and a "built" RE401RB box is marginal i think once i fit turbo and run 22psi with the weight of the car. I just wanted to take no chances,as heat is the biggest killer of auto boxes . i found one cooler with transbrake and slippery converter wasn't that great in R31, will be having 2 in R31 next time aswell, its quite normal in the U.S, here i only commonly see one fitted.
cheers
darren
My cooler setup, two 30 row coolers, one 12an for oil and one with 8an for the trans. (plus the PS cooler.) Not much room left. lol.
The engine oil cooler has a 14 inch fan on it, and the transmission one has a 9 inch spal. Both fans electronically controlled off temp sensors in the cooler return lines.
Mine is a bit more of a squeeze than that. I dont have room for fans and my coolers almost touch side by side. Even with the grout in the block water temp still seems fine :thumbsup:
Edited by WHITER33GTS-T
hey guys , as stated above heat is the killer of auto boxes
recommended transmission coolers for my r33 gtst series 2 for easy fitment and good quality?
how much should I expect to pay to install it? (cant and wont do it myself as im mechanically retarded)
get the biggest one you can from Supercheap or whatever - shouldn't be more than an hour's labour to install - get some quotes if you're worried.
Read this even if you don't plan to do it yourself:
http://www.skylinesaustralia.com/forums/topic/59399-transmission-cooler/
  • 3 weeks later...
Replace the coilovers with stock suspension, put smaller rear wheels 15/16 inch with street drag radials, hi stall torque converter, mv auto shift kit have some fun.
My question, how much can a stock 32 auto take? Has 33 turbo with vg30 rear housing and supporting mods.
Thanks for the advice. Its my daily and I want a nice looking car with a bit of poke , so I dont really want to ditch the coilovers and run 16's.
Would a high stall &/or a shift kit net me a second? really want to get into the 5's
what are you guys doing 0-100km/h in your auto's?
A shift kit is a must at much over stock power.
All a high stall converter will do for you is to lose you power, but it may help get you off the line a little quicker. If you have the stock turbo, leave the converter alone.
thanks for the input. Why exactly am i so slow getting to 0-30km/h and the engine only really starts pulling hard to 100? Cant be that much turbo lag since its only a tiny turbo on the rb25
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
