WazR32GTSt
EXCELLENT IDEA!!!
Although, ....would it be possible to include what post number it is next to the user name in your layout?
EG:
rb25 - R33, R34, or Stagea
DYNO
255rwkw - Abo_Bob #9
220rwkw - 4door_sleeper #15
191rwkw - SECUR1TY #12
That way we can go straight to that post number rather than sifting through the whole thread trying to find what was done to that car/auto to achieve that figure....
cheers
P.S: Will post up my figures when i have em...
i could... but i personalyl think that would make it kind of confusing...
maybe after a while i could compile a list of the "best automatic mods" in the first post as most people are heading in the same direction with their modification route to achieve similar results
and on the not of results.. i had a new justjap intercooler and BATMBL split dump installed yesterday..
old setup was 3" bellmouth dump and small FMIC and was 155rwkw @ 14psi.. new setup made 170.4rwkw @ 13psi!!!!
and that's on the rb25 turbo!
R31 skyline, Rb30, Gt42 roller
378rwkw on 23psi, pump fuel
Mv automatics Re401RA trans
manual valve body
custom second gear hub
stage 2 shift kit
trans cooler
presently no 1/4 mile time as we have no track and i can't get
the auto to be reliable at the moment it is back at Mv's again
might be to much power for it, so you will have to look at the 300zx/patrol
box for over 300rwkw, or a powerglide/3 speed jatco etc maybe,
he is disecting it at the moment
cheers
darren
Guess i'll be the baseline...
142.1rwkw .... 11/1998 R34 - stock as a rock. Haven't run it on the track yet, they cancelled street meets at adelaide international raceway.
Edited by Howie
  Abo Bob said:
They are all anti auto fascist zionist cops!!!!
lol - picsorban !! :P
Gotta love the auto, I'll never go manual again. If only a PowerFc would work with the auto, if only.........
unfortunatly, ill always want to go manual.
i know how to drive an auto hard, trust me, but there is just something about a manual that does it for me.
i guess it could be that i can just cruise a long, 2nd gear, revs and pop cluch and out it comes!
i also find the manual is less hard on the brakes due to engine braking being more useful.
anyway, not to take away from the auto. for a 99% daily and 1% fun car, an auto is great! (too bad i seriously injured mine :P)
S1 R33 auto, 185rwkw with the following mods:
FMIC
3" exhaust from the turbo back (stock turbo)
AVCR at 10psi
Emanage blue (with only injector harness)
HKS pod with heat shield and CAI
Nismo FPR
Walbro fuel pump
Stock injectors
Stock auto transmission
I'll have to find the dyno sheet, will post up soon!
R33 (s1.5) with 203rwkw @ 12.5psi
(turbo & torque converter still stock)
Stage II shift kit
MV electronic shifter unit
Pro-ratchet shifter
Trans cooler
Power FC
EBC
Pod filter
Z32 AFM
FMIC
3.5" Turbo back
044 fuel pump
740cc 'overkill' injectors
Splitfire coils
Cam gear - exh
Oil cooler & thermostat
Havent run the 1/4 with current setup.
116000kms 1989 rb20det
rb25 standard turbo
3" dump-tip
R34 smic
standard airbox
S-AFC-1
RE4R01A(crappeiest of the crappest)
nothing but the outer case is originial.
2500rpm converter
165rwkw @ 12psi
very linear power curve(laggy)
PWR tranny cooler
Edited by RSTME
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
