Not saying it's a good idea (personally I reckon it'd be a bitch on fuel, plus no fun to drive) but from memory there's a QLD GTST, and one from Vic running powerglide transmissions. Both are daily driven. Not sure if there's any info on SAU, but could be worth a look.
There is a marron gtst with plates H8 GRIP or something like that in qld that has a powerglide in it.
YouTube r33 powerglide it's the marron one
What trans temp does it run at...?
I am using a 30row engine oil cooler for mine. Trans temp hasnt gone above 60degrees while having some spirited driving.
f**k knows, its just the car to take kids to school ..i put them both in there as i had them sitting around and a "built" RE401RB box is marginal i think once i fit turbo and run 22psi with the weight of the car. I just wanted to take no chances,as heat is the biggest killer of auto boxes . i found one cooler with transbrake and slippery converter wasn't that great in R31, will be having 2 in R31 next time aswell, its quite normal in the U.S, here i only commonly see one fitted.
cheers
darren
My cooler setup, two 30 row coolers, one 12an for oil and one with 8an for the trans. (plus the PS cooler.) Not much room left. lol.
The engine oil cooler has a 14 inch fan on it, and the transmission one has a 9 inch spal. Both fans electronically controlled off temp sensors in the cooler return lines.
Mine is a bit more of a squeeze than that. I dont have room for fans and my coolers almost touch side by side. Even with the grout in the block water temp still seems fine :thumbsup:
Edited by WHITER33GTS-T
hey guys , as stated above heat is the killer of auto boxes
recommended transmission coolers for my r33 gtst series 2 for easy fitment and good quality?
how much should I expect to pay to install it? (cant and wont do it myself as im mechanically retarded)
get the biggest one you can from Supercheap or whatever - shouldn't be more than an hour's labour to install - get some quotes if you're worried.
Read this even if you don't plan to do it yourself:
http://www.skylinesaustralia.com/forums/topic/59399-transmission-cooler/
  • 3 weeks later...
Replace the coilovers with stock suspension, put smaller rear wheels 15/16 inch with street drag radials, hi stall torque converter, mv auto shift kit have some fun.
My question, how much can a stock 32 auto take? Has 33 turbo with vg30 rear housing and supporting mods.
Thanks for the advice. Its my daily and I want a nice looking car with a bit of poke , so I dont really want to ditch the coilovers and run 16's.
Would a high stall &/or a shift kit net me a second? really want to get into the 5's
what are you guys doing 0-100km/h in your auto's?
A shift kit is a must at much over stock power.
All a high stall converter will do for you is to lose you power, but it may help get you off the line a little quicker. If you have the stock turbo, leave the converter alone.
thanks for the input. Why exactly am i so slow getting to 0-30km/h and the engine only really starts pulling hard to 100? Cant be that much turbo lag since its only a tiny turbo on the rb25
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
