  • 1 month later...
Man what happened to all the auto guys? This thread is dead...
Are these the options or tuning the auto skyline r33 :
Toshi's tune
Nistune..need more info about this
eManage blue/ultimate
Safc and sitc
Power Fc
Are these users able to retain the shift logic? Toshi is all out of auto ecu's and wont be importing anymore so I dont know if he is an option. He mentioned not being able to do over 200rwkw or so on the eManage.
Want to see in excess of 230rwkw (have usual mods - intake/exhaust , injectors , fuel pump - high flow turbo to 18psi , trans cooler , mv valve body upgrade)
What ecu can I use that will retain daily drivability but get me to 230rwkw?
A few Options
Adaptronic E1280, Wolf 3D V550, The Newer AEMs can do it, Holley Dominator EFI will do it shortly
Toshi's tune
Safc and sitc
Power Fc
A few Options
Is this true. We used to be looking for ecu's to retain auto shift logic everywhere. Have I been that behind the times or do all the above retain the auto boxes shift logic in an r33?
Stu released a Type 6 board (still beta/prototype) to nistune your stock ECU (in the past had to be a Z32 8-bit ECU)
There was a thread started in this forum, however r31nismod decided to delete it because it sounded too much of a trader ad.
You should speak to Mat from Nistune, he might have a solution for you retaining your factory ECU, however with the new type 6 nistune board.
I, myself have not used (type 6 that is) however it looks very promising, have however used/tuned other nistune vehicles and it's great.
They're piggy backs. dvs jez has tuned an adaptronic on an auto 33. If i recall the mods correctly it would have had around 280kw
Thanks will have a look and report back
best part about nistune is their trace functionality, shows you a load trace and display afr or whatever value you want
other ECU software you need to log, then read the log for that view (just makes it a tiny bit more time consuming)
I've been following Stu's post, seems the 1st batch were slightly dodgy however it appears it may have been fixed.
Why? If he is worried about knock, shoving e85 in the tank will fix that...
I have seen 250kw easily on petrol safely, and over 300kw on my Ethanol Emanage Ultimate tunes. I can't see why the VQ would be any different to RB tuning...
I think he's missing a vital piece of information, and that's probably the stock automatic gearbox will go kaput with over 200kW
Only just found this thread so sorry if i have missed this but y cant we just put a manual valve body in and wire the od switch into a diffrent power sauce and just run a manual ecu ? O and I have a r32 with 220 rwhp probly a bit more now and a 3500rpm converter and loving it.
I believe you can do exactly that.
It is also possible to have a completely standalone computer (at least for the R34) for the automatic side of things. This is probably 'better' than going full manual, because you can configure absolutely everything that a transmission can do.
    • I dunno. I just go off what I know works. On RB20, the idle switch meant something to the ECU and the potentiometer was ignored. In Nistune, with the switch unplugged, you could bridge the terminals in the loom connector and see IDLE come on and off. Not so by moving the pot. The R32 RB20 ECU and the 26 ECU both look like this. Sure there is the "throttle sensor" (pot) on pin 38, and also sure, the idle switch is also directly wired to the TCU, whereas the pot is only directly conected to the ECU. But I am sure that the throttle position from the pot is passed to the TCU across the data bus on pins 21, 22 & 31. Maybe the ECU likes to know throttle position, but it sure as hell doesn't use it to determine the idle condition. Meanwhile, on the later engines, like the 33 25DET and my Neo, you remove the TPS and move the pot to-from the 0.45V position, and IDLE comes and goes in Nistune. No throttle switch on the ECU diagram. Just the pot.
    • So, good news and bad news Bad news first: The intake plenum is lost in the mail apparently, I haven't paid for it yet, and MX5 Mania are still chasing it up, farking 'Merica postal service  Good news: Any retune will be free if and when it turns up,  I'm still keen for them to throw it on The car goes noticeably better, with only the typical initial take off thingie from a choppy cam and manual transmission, but giving it just a little more RPM than before gives it a smooth take off (and hour or so of peak hour traffic sorted that little skill out) Car made around 145kwatw & 225Nm (Intake may get me to 150kw, maybe....馃ぃ) Weirdly, 145kwatw is the same max power that my standard 2015 WRX STI made a few years ago The cam really comes alive from around 3.5k and keeps making power and holds it flatish all the way to 7k, whereas before torque would drop hard around at 4.5k Drive home was sadly in peak hour, although I did get a little clean air here and there to wind out 1st and 2nd a little bit, and whilst the gains aren't anything for the "boosted boys" to be impressed at, the thing is a blast to drive The sound in the vid is poor, as it is in a undercover yard at work, but, outside, in the wild, it sounds awesomeballs to my ears with all the choppyness I consider it money very well spent for the outcome  Cam specs for reference (Basically the biggest you can fit with stock pistons) 20250417_171807.mp4   LOL, I don't think I will ever grow up
    • Swap the injectors around and see what happens. If the misfire follows the injectors then that's a signal, if it doesn't it's probably not the injectors.
    • R33 with RB26 seems to go off of learned voltage for idle. Seemed like whatever the baseline voltage was once ECU first gains power will be the idle voltage. With ignition on unplug/replugging the TPS would relearn the idle TPS voltage.
    • Have you confirmed the 2 pin coolant temp sensor on the motor is working properly? I've had a very similar issue when I forgot to plug mine back in many years ago.
