Waz; *politely* S-A-T-A-N-I-C ;) Cheers Bro!
666DAN; would've been more; just need a nice boost controller or someone who knows how to use the Hybrid EBC properly :) then I should be closer to Abo's number!
  • 1 month later...
thought i would list my mods since i have an auto r33
Hks frount mount intercooler
3inch turbo back exhaust with metal hi flow cat
GCG hi flow turbo 450hp
Greddy profec A boost controller
Apexi Safc 2
Apexi Sitc
Bosch 040 fuel pump
Sard Fuel regulator
hks cam gear (not currently installed)
Standard injectors
Z32 AFM
Stock transmission just with tranny cooler
Mv Auto Shift kit (in the process of buying)
I Have had the car for 4 years have considered converting to manual but i have alway's liked the auto. I got car tuned a couple of weeks ago and got 196kw at the wheels before i maxed out my stock AFM on 10.5 pounds. Last week bought a Z32 afm and retuned the car and made 229rwkw on 14psi. but now worried about the transmission since i have already blown one and don't want to kill another so i am hoping the shift kit should be able to cope with the power alright.
It is yet to be run will go to calder when the Mv valve body is in.
wife's daily driver..
s1 r33 4 door
rb25det
acl forged pistons
eagle rods
Jun crank collar
N1 oil pump
new nissan water pump
ARP main, big end, and head studs
full nissan gasket set including head gasket
standard head
standard plenum
standard coilpacks
stainless low mount manifold
gt3582r-iw
custom 3 inch dump
full 3 inch stainless system
ASE FMIC
sard FPR
bosch 044 intank
apexi power fc
q45 AFM
custom 4 inch intake
nismo 550cc injectors
current power is 317kws
with ignition advance average around 18 - 19 degrees
i have been advised that if i drop the boost to say 20 - 22 psi and increase the ignition advance to 21-22 degrees the power should head up towards 330 - 340, without to much pinging.
but thats yet to be proven on my set up.
standard trans
mv stage 2 shift kit
large trans cooler.
Very nice mate ! Are you ever going to have a play with it on the strip ? Would be cool to see what mph it pulls !
What afr's it running top end ?
its near level on 12 afr once on boost.
im planning on dropping that down to about 11.5 afr then pumping some more ignition advance into her.
Hey i would love to stretch her legs down the strip but we dont have one.
bloody government over here are slack, and private enterprise is even worse.
Glad I found this thread... I will add my Datsun 120Y that has a RB20DET auto
Engine has
20thou forgies
Walbro + Bosch 044 & surge tank
GTR ingectors
Stock AFM just before the throttle body
3" exhaust
Garrett GT35R 0.63 exhaust
38mm Turbonetics external gate
Auto has
MV shift kit
MV manual shift controller
B&M pro ratchet shifter
4200 stall converter
trans cooler
185 kw
I could only find my 13.1 @ 113 timeslip from yesterday but it has done a 12.9 @ 113.
Best 60 foot is a 2.25
I use 205x50x16 Toyo R1-R and a 3.7 lsd diff.
I have been told I have the incorrect type of muffler fitted and i need a straight through design.... Damn restrictive V8 muffs.
post-24062-1162824263.jpg post-24062-1162824293.jpg post-24062-1162824441.jpg
Edited by RB120WHY
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
