  • 4 weeks later...
Just a mini update. I have swapped out the 550cc nismos for a set of 740cc nismo's.
And the new LINK G4 Plugin has finally arrived and i installed it, with the aux cable as well for extra inputs. What a nice bit of gear.
I was previously running the LINK GTST Plugin, and this is so much better, finally all the features i want !
Throttle response is much better... something that was bothering me prior. Hopefully on dyno this saturday if its avail to me.
Still have to swap out the 040 bosch pump for a walbro. The bosch ran out of flow previously, so im going to try a genuine walbro to see how it goes. I measured the pump voltage first just to make sure the supply wasnt crook. (i have already earthed out the negative to bypass the switching). And volts were 13.6 odd.
I even pumped in 30 psi into the actuator to load the pump, and volts were stable.... so definately will change it this week.
Ok, stay tuned !
Gary
Got onto dyno this sat to have a play. Found a few weird things with timing with the New G4 Link .... still looking into them.. however, as much as i tried, i could only get 257 RWKW (1417 N.M in 2nd gear) ..... so HKS manifold and proper .63 Turbonetic housing didn't do much.... Shame.....
Still think i have a problem..... yet to check cam timing to verify 100% there not a tooth out etc, and also , test the TIP (turbine inlet pressure), and the HKS now has a threaded hole at the collector to measure it..... to glean if the housing is simply out of puff...
The other variable is the auto/histall..... but a few others have made more on a very similar auto ... abeilt with bigger turbo...
Im very tempted to try to swap in a stock converter for a run..... just see what happens.
Anyway, running on link's internal map now , so using the 2.5bar link map sensor plugged into old MAF wiring (as used in GTST LINK) , for a second GP Pressure sensor, just need to T it into the turbo outlet to check full cooler and piping loss. Did i mention i love the new link G4 ??? :P
Until next time !
Gary
Just cause i can switch it into snow mode and then put the t-bar in 2nd and it never jumps out of 2nd.... you can floor it happily and load up against dyno before a run.
Yes the torque is getting pretty extreme though..... although it doesnt spin on the dyno. ! Hops up on the roller pretty decently though.... i should get a video.
So wheelspin out of the way, its just falling over. Once i measure the TIP pressure i'll make a decision from there.
Will try to get to drags soon. Charters Towers 1/8 mile social meet is on in 2 weeks... but then i'll do a full quarter run and see if its improved from best run.
740's are at 73% duty cycle, at 11.8 AFR.
Oh, and intially it felt like crap on the street, however, its the only known problem with the Vipec/LINK G4 , in that with the autos, the factory applies +12v to the tps SWITCH (for auto comp), whereas the Vipec/G4 only puts 5V....
So auto comp thinks car is at idle always and changes very early, and takes a while to go to first once stopped.... ie stop sign might see you taking off in 2nd !! Manual shifting got it lighting tyres again.... will rewire that wire when i get a chance
Gary
Gary
Its very wierd that both our cars are behaving like this
I havent been back on the dyno since I have fixed a boost leak
and I was also wondering if maybe the timing is out from when I did my 100thou service
consult shows my base timing at 5deg at idle but i haven't been able to check the physical timing yet
I'll let you know if i find anything of course ! You going to towers ?
Where was the leak ? My pcv hose is split and needs replacing i noticed on sat.
Gary
Edited by Fastrotor
just on the hot side exit of the turbo at the 90deg bend
it was a bloody band clamp ,it had locked up on me and i thought it was really tight so i left it be
turns out it wasnt and was leaking pretty bad
which may explain why when we went from 14psi to 18 psi it would only go up by 2-4kws poor bloody turbo was working its ass of to make 18
it does drive different now with the boost fixed
way more responsive lol
Good stuff Pete. I am going to bung the inlet and pump in 20 psi and check for leaks also, as this could be happening to me also. Might go the reverse way and do the same for the exhaust.
Gary
Gary
Gary the magic brown plug fixes all
surely you have read my posts on the brown plug?
behind the drivers head light there are 3 eletrical plugs
when you disconect the brown one it locks the trans in 3rd.
so reverse onto the dyno, open bonnet, unplug brown connector, put in drive, and away you go in 3rd gear.
obviously it stalls up a bit cause your taking of in 3rd but it cant possibly kik back on you as its locked in.
so its easy to tune all the light load points as well.
:D
Darren
Ahh ok ... gee must have missed that one, either that or just forgot about it. I'll give it a shot next time im on there in a few weeks. I wonder how that affects the transmission line pressure at all ?
It makes sense as when researching the ecu (i built my own pcb to replace factory one) i did notice the 3rd shift is both outputs just off..... so hence why your trick works no doubt !
Thanks for the heads up, and yeah that will help with low down tuning.
Once i get my auto comp running, i'll just lock up the converter for low down.
Mike at MV reckons locking it once in 3rd is ok on strip..... so i guess on dyno wont hurt either...... be a good way to figure out how good/bad the converter efficiency is i reckon. Still im scared of smoking it !
thanks Darren
Gary
Hey i thought you were manual 2rismo !! Nice, welcome to the club ! Will go quicker as is just not hitting the limiter.
What 60' was it doing ? Dyno sheet ? Hows the responce with the 1.00 A/R ??
Gary
Edited by Fastrotor
Just a quick one... not sure about the autos on the R33 but definitely on the R34; tuning should be done through 1st, 2nd and 3rd to get it precise, not just in 3rd. This was the case with mine, we initially just tuned it in 3rd and there were issues when under WOT in 1st and 2nd, took it back and weeded it out.
It'll be quite a time consuming thing to do as in 1st and 2nd WOT, the revs build rather quickly - but it'll be worth it to achieve a solidly smooth graph.
Gary
No dyno sheet. Didn't bother to print one. I drove it off the line for the 11.7 so the sixty was a yawn-worthy 2.0 seconds. It weighed 3250lbs race weight so you can do the math if you like. The response of the 1.0 rear is fine with the big converter but there's a lot more to come.
Stan, technically gearing shouldn't make a difference.... probably just couldn't get into areas of map in 3rd, whereas 1st and second got there..... This is where locking the converter up in 3rd would allow you to get to all the areas a manual could, without the humungous torque trying to break straps and such!
2rismo,
Oh ok, thought the launch looked abit soft for a transbrake ! Have you done a 60' with the TB ?
Is the converter a lockup one ?
mine's going back in a week for more finetuning
poncams want setting up a little more, got the intake injector setup and controller to perhaps go in along with some guages
did my oil and sparkies yesterday but will get the shop to flush the coolant when undoing the drive shaft
then do some tuning in 2nd gear hold and 3rd gear brown fuse trick
if we put on the extra fueling Im expecting ~235kw, so we'll see soon.
2rismo,
The converter is a 4k-ish TCE that locks up when it can. :) i could only get a few psi on the footbrake so it tool till 60' to come on song. I have only had one pass on the transbrake and lets just say the radials didn't like it. Even letting it go at 8psi. More refinement is required.
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
