Thanks mate
Also, do you have the auto steering wheel? I'm after one in very good condition
yeah ive still got the wheel, its in very good condition. Im selling it with the airbag though...
will send pics for that aswell
Steering wheel:
http://i105.photobucket.com/albums/m238/Ms...80/DSCF3179.jpg
Edited by msports180
I would do the wheel with the airbag for $450+ frieght
I do have the leather handbrake surround, have someone interested in the hole console atm. Will let u know.
Neil
I have some R34 sedan parts available, Most are out of the car atm. Im in WA, will post at buyers expense.
Rear Leather type Seat, light and dark grey no rips or tears $450 (door trims have matching leather inserts pm for details)
Front seats standard type, no stains, tears $300
Auto steering wheel with airbag good condition $500
Passenger Airbag $400
Factory Auto Dash cluster 73ks $250
Air Con evaporator/fan box $200
Air Con Condensor $100
Heater Core $50
Rear Door trims, good condition $100 (leahther inserts)
Carpet, grey, no stains $100
Interior Trims : offer's?
Auto Gear Box $450 with tiptronic shifter *** ON HOLD ***
Factory LSD $400
Centre Console $50
ABS module $200
Seatbelts $50each
Interior Lights $30 each
Hoodlining $50
Hicas Pump on diff $100
Pwr steer resevoir $40
3 gauges on dash (gauges only, not the pod) $50
Probly other bits and piece's pm me
I dont get on here very often so best to sms or ring me 0419943997
Hi,
I am after drivers seat belt as mine is a little sticky and does not retract tight immediately. If what you have does not do the same then I am interested.
Also after drivers door rubber seal/surround that clips onto car body.
Price delivered to Melb CBD please?
Thanks.
bump again
offer's?
need to sell
waiting price and availability for drivers seatbelt and body door rubber trim.
Under hard braking say at 100k's I get bad front vibration, would this be dodgy ABS unit?
Handles perfectly at lower speeds.
Thanks,
Paul.
Thanks,
Paul.
Hi sent you a pm
Can do seatbelt for $60 delivered, my door seal aint that good.
The vibration sounds like maybe a rotor problem, like either warped or needs machining. Id love to say its the abs unit but i dont think it is.
Neil
Guest
    • Nah it factory manual not sure about ratio but it looks like there’s been some work at the rear
    • so I need a new speedo cable
    • Throwing my spoon to the soup here a bit.  When I installed a 044 back in 2012, along with the direct power mod, the car became very difficult to start. To a point I burned one starter motor as I was late for work and tried to get the thing going. With some tuning and careful use of gas pedal when cranking it became bearable. Trying to make this short as possible, but the 044 died after 2-3 years, after which I went with an AEM 320lph pump, which also died after about 4 years to my dismay. After that I went with a Nismo pump, and while trying diagnose an emissions problem, I noticed for the first time that my fuel pressure was 5bar/72psi on idle, and that removing the vacuum line did nothing. After monitoring the situation, and removing the direct power feed and going back to FPCM in attempts to remedy it, I noticed there was fuel in the pressure regulator vac line. Kept the FPCM, installed AEM external regu and the car became sooo much better in every way, including starting. And I had driven it like it was for 11 years.. Anyway, I agree these are likely two different problems, and the FP problem you just haven't noticed before. I do not know much about haltecs, but what first came to mind was the CAS, which probably is not there any more. So how is the wiring from haltec to gauge cluster? How is the battery voltage and alternator?
    • Your car was auto before? You have different diff ratio (auto vs manual i think? or n/a and turbo?)
    • +1 for getting a screen off alibaba, CarPlay/Android Auto is vastly better than whatever navigation cars had 10 years ago. I got an Android screen for my 2015 BMW, huge difference. Fully compatible with factory stuff including iDrive controls.
