Hey all
just venting some anger
today i was driving home from work, theres a point where you have to merge at the top of a hill, i indicated for about 10 seconds hoping that some kind person would let me in. The person in front of me (in the other lane) sped up a bit too let me in, but then the FAT F*CK behind her sped up, therefor not letting me in, he looked straight at me and smiled. OMG! That was it, he then had the nerve to cut me off about 5 minutes later. I drove up next to him with my window down signalling to him to wind down his window down for a "friendly" discussion. But the prick wouldnt even look at me. All I am trying to say here is, Dont be a top bloke by not letting ppl who have signalled in PLENTY of time in.
Cheers
Dave
P.S: I am not normally like this but enough is enough I reckon. Its a little thing called commen courtesy but evidentely no one knows what that is anymore!
https://www.sau.com.au/forums/topic/13150-farken-road-rage/
I wouldn't take that kind of attitude... nowadays, if anyone pisses me off i tail gate or swerve and cut them off the road. I guess one day I will meet the wrong person and have my face punched in.. but i'm full of rage!
Look im all for that in some circumstances but cause im big, ppl tend to think that im always looking for fights( sometimes i am) but, look i dunno most of the time i will tailgate someone that has pissed me off but i just couldnt believe that farker. OMG! Bashings for him, TO THE HEAD. BWUHAHAHAHAHAHA
https://www.sau.com.au/forums/topic/13150-farken-road-rage/#findComment-249653
Well by law, if someone in another lane is indicating, and is in front of you, you have to let them in.....
I always indicate with heaps of notice, and people usually let me in. I dont like to wait for a gap, then indicate.....
But when I see some mofo speeding up to not lert me in, I swerve into that lane hard (only about 1/8 th into the lane), the other person usually brakes hard, then I slowly take the lane..... :P
This technique is effective about 80% of the time it is used... maybe more...
https://www.sau.com.au/forums/topic/13150-farken-road-rage/#findComment-250550
    • Actually, that's not entirely true. It's also the same motor in the 1st gen Nissan Cube but they're rare as hen's teeth.
    • Yeah it is always worth testing and balancing actuators out of the box, just set the pressure regulator on a compressor very low (eg 5 psi) and increase it slowly to see when they both move.....unfortunately while you may be able to adjust the length of the actuator rod to minimise any difference, the actual pressure they move from is not adjustable so you need a well matched pair. And yes, the VCAM is probably contributing; the earlier in the rev range they come on boost and the slower the revs build (I think your demo was in 5th), the more you notice it.  Driving at WOT through 1st, 2nd, 3rd etc you will probably never hear it as any shuffling starts and is over super quickly
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
