I've just brought an Eclipse AVN6000 for my R33, looks like it'll be a nice unit, but a little tricky to install.
The brackets from the stock double din tape/cd/radio look like they will screw into the side of the Eclipse unit. However the Eclipse looks like its slightly smaller in height. I believe if i put the dash on, there will be a 4mm gap above, and 7mm gap below.
Any ideas on how to make a cover to hide this gap?
Has anyone had similar experiences when installing a double-din unit into an R33?
We usually just make up an plastic surround. :(
Looking at the way the unit is mounted in a Skyline, i guess this plastic surround would pretty much hold itself in place, maybe just a few dabs of silicon behind the surround to hold it there? Then the dash will push down on top and keep it there?
Is there an eclipse expert here?....
Is there a difference between an AVN6000, and a "Toyota AVN6000" ?
I'm wondering if i've been sold a Toyota unit, because the harness came with plugs at both ends, and the unit does not appear to have RCA outputs.
My next dilemma...
does anyone know how much the "converter cables" costs for the AVN6000 to allow you to get RCA output?
The AVN6000 comes with the RCA output cables included in the box with all the other Audio Visual input and output cables. If you didn't get them, check with the dealer you purchased it from.
Drew
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
    • Was that Australia Delivered Duncan? Does it have siren etc?   I used to have remote start on an old 32 two decades ago, it was a cool feature. I used to wake up early in winter for work. Start it and by the time i was out the door a few minutes later the engine was warmed up and the heaters had the car toasty. It was great.    I don’t mine the ambience lighting.  I drive a western star and it has footwell lights and ambient lighting and it’s great! From the pics of seen of them installed in a skyline I think it’s a nice touch
