Hi guys
My post was specifically for a SII R33 Sedan, in case in the future someone searches and this thread comes up, just for future reference, didnt mean to cause anyone confusion.
Below is a pic of the packaging of the globes that are now in my car. It a dual filament, one for high beam one for low beam (not two separate globes) . R33 sedans have different lights to the coupe, apart from the driving lights and the parker lights, they also have a indicator light which lights up to throw light around a corner (not sure if coupes have this, but i cant live without it now ;) ), also obviously the chrome inside and the lens is not clear like the coupe.
Hope this makes sense
Notice H4 in top right hand corner.
Head on you can vaguely make out only one reflector for high/low beam
In this pic the indicator/corner throwaround light is next to the silver bit at the corner of the headlight
cheers
Evil
Hi guys
cheers
Evil
Well i'll be farked. thanks for the tip evil. :D
    • You would probably do a lot better in a claims process then most people. When I called the insurance company, they were surprised I read the pds because according to them almost no one does lol.
    • Yeah it should be, but I wouldn't be surprised if the insurance company tries to pull some argument out of their ass to avoid paying you out.
    • On some cars like MR2 Turbos they're notorious for not letting the wastegate open far enough to avoid overboost, especially certain cheap downpipes. If adjusting "percentage cycle" fixes it then it's just an electronic control issue, not a hardware one.
    • Same.  It's depressing to say this but the skyline can go months on the charger between drives.
    • I often leave mine connected weeks at a time. The main one I use is the old model of this, it has 2 important features - choose battery chemistry other than lead acid (most of mine are AGM) - power supply mode which you can use to try and recover dead flat batteries as "smart" chargers often don't recognise a dead flat battery is connected https://www.projecta.com.au/products/IC10/intellicharge-10a-bat-chgr The Ctek I  use was meant to have a battery test mode as well but it doesn't work 100% of the time so I am pissed at them. The distributor did everything possible to make warranty and support difficult so I'll stay away in future. The main thing with a "trickle" charger is it has multi stage programs, ie once the battery is full it turns the current right down to just maintain the charge....in the old days we just used real "trickle" chargers for that which had a maximum output of say 500mA which was safe to just leave connected to dumb old lead batteries.
