Hey Guys,
I have just sent my car to the mechanic and he will be looking at it 2moro but i would be interested to see what you thought of the issue i am currently having.
Basically the car runs fine day to day and the only issue i have is that when the car is pushed it starts to rev fine, but then around the 3500 - 4000rpm mark its struggles to rev and feels unwilling to rev (almost like petrol is not gettin through properlly) and then towards 5500 - 6000 it seems ok again. But my friend and i drove it the other nite and he could tell straight away (also a 32 owner) and im starting to worry.
It has been this way for a while but because i dont rev beyond 3500 too often i didnt pay much attention..
So yeah, any ffedback appreciated
https://www.sau.com.au/forums/topic/131546-engine-issue/
Oh ok, i was thinking it would not be a major problem as in general the car is fine and the problem is only under hard driving in that specific rev range as i said. My main concern that it was not major as in like a few cylinder loosing compression and a possible critical problem in the block. But i guess i just wanted assurance...
cause wen i want to drive faster now i generally drive to 3500 which its fine to and then change, but in first gear off the lights its more likely to rev clean right through to 6500rpm and the problem happens more in 2nd, 3rd, 4th
https://www.sau.com.au/forums/topic/131546-engine-issue/#findComment-2435222
I had the same problem with my r32 gtst. To fix it I made put the timing forward, the tiniest bit. and the problem was gone.
I checked all my coils and plugs and they were fine so this was a last resort.
It worked. *shrug* dont ask me why.
hope this helps
https://www.sau.com.au/forums/topic/131546-engine-issue/#findComment-2435242
I think there ia a tutorial, mabey sticky about the coilpacks cracking due to heat, check it out :ninja:
Here tis'
http://www.skylinesaustralia.com/forums/in...showtopic=32356
Hrrmm after reading this im not sure this would be my issue, ad the car only has a 3" cat back and pod filter...otherwise stock and has been all its life, i bought it in original nick with not a thing touched, and its never been boosted which seems to cause the problem with the coil packs due to the increased temp
https://www.sau.com.au/forums/topic/131546-engine-issue/#findComment-2435257
hope this helps
Actually its interesting you say that, because my mate when i got the car helped me do first service and was suprised at the position of the timing as he used to hav a 32 and knew a bit bout them and did a lot of work on his car. Ill mention it to mechanic..
https://www.sau.com.au/forums/topic/131546-engine-issue/#findComment-2435264
Also I have noticed when the car is just started (cold) and then driving it is more noticeable, it just seems really unwilling to rev, its like ur asking to much and the fuel is just sputtering in as u build up some revs so i dont push it, but i know when i tested it (a year ago when buying) we cold started and it was more than happy to rev hard and it pulled hard and quick, i dont know what spark plugs the mechanic put in it last time also he didnt use synthetic oil (which he will this time after i asked him to) but i doubt thats related
https://www.sau.com.au/forums/topic/131546-engine-issue/#findComment-2435282
    • Welcome.  800hp should be a bit of weekend fun!
    • I'm going with "Just run two gates". Fix the problem conclusively. It's the only way you'd ever truly know, right?. This is all pretty much splitting hairs. Even the extreme example where it takes two whole seconds at 100kmh or something sounds monstrously dubious. And anyway, when you're punching the throttle when you 'need' this power, you aren't at 2800rpm in the wrong gear. Test it at 5600rpm in 3rd gear, when you're traction limited punching out of a sweeper. Much difference there when you account for traction?
    • And the full R32 GTR wiring diagrams are also freely available. Hmm.... there's supposed to be an auto replace that would have linked the thread. Here it is, manually
    • Ahh...should have been clearer ~ there's 2 ... SMJ = super multi junction (connector)...   ...this is connector 6 & 25 in above image -- body harness to engine loom (6) & body harness to main loom (25) Headlights go to front via connector 6 ; fuel gauge goes to tank sender via connector 25  ...like I say this is R33 diagrams, but at a pinch R34 won't be too far different. *IF* the two ground faults are related, this can be the only place where both wires converge (as one runs to the back, the other to the front)... ....thing is, you probably need to establish if the faults are related (unless you examine that area and find obvious chaffing on the looms there to body ground)....*IF* the fuel gauge is still broken (full needle deflection), I'd be headed for the boot, remove fuel sender wire, key on and measure the voltage there ~ it should be roughly 10volts. If that's ok, check sender to ground resistance...if this is a dead short to ground (and there's fuel in it), then sender has failed or something funky has happened to wiring in the tank. edit: ahh...rereading the thread, this is R32....above fuel sender test still valid tho'
    • I just changed the timing belt on my RB25DET NEO and wanted to get some opinions. I’ve been super cautious, did a lot of research, and took my time. I’ve driven the car, and it runs fine. After warming it up, I revved it to 8000 RPM a few times—no issues, everything held up.   After the drive, I heard a noise that I think is either the clutch or possibly a tight accessory belt. It’s not constant, just comes and goes.   I took the timing cover off to double-check everything:   Belt is on properly, Tensioner is tight, Did the 90-degree twist test—belt isn’t too tight or too loose.     What still worries me is that I noticed the belt seems to sit a little toward the front edge of the gears, especially on the idler pulley. It even looks like it’s slightly coming off the edge there. Is that normal?   My old belt (5 years old, ~3,000 miles) also showed a bit of wear on that same edge, so maybe it’s just how it sits? I’m probably overthinking this, but since it’s my first time doing this on a NEO and the engine is forged, I really don’t want to mess anything up.   Also, I’m thinking of swapping to a clear front timing cover with the glass window. Would you recommend NITO or HPI? HPI looks reputable and their covers have 2.5mm thickness, but not sure if there’s a real difference between the two.   Any advice or reassurance would be much appreciated!
