  • Replies 51
Posted Images
if you want to shorten in to get the best response, change to a top mount cooler. you will cut a fair bit of piping out, but will get major heat soak.
also for those interested in power loss from aircon, at a dyno comp i was turning off the aircon and the dyno guy started telling me about a toyota coaster (small bus) that the aircon took 17hp out of the motor. i know cars don't take that much, but we used to have a subaru sports wagon and it made a huge difference (but it was a really gutless car. 62kw at the flywheel, and weighed about as much as a skyline). i'd say it'd probably take about 5hp.
i just compared the v mount setup to the standard setup, and the piping length difference is simple due to the tighter angles on the cooler. if you tightened the angles of the bends on the cooler posted by EXAUNV then you would get the same affect. also using the aftermarket plenum gets rid of some piping, but makes up for it in extra plenum length.
there is an illusion to that with aircon, without aircon dyno. the illusion is that the aircon run was done second, and as most people know, turbo cars generally dyno the highest on the first run due to heat soak. and it was done in feb, which isn't the coldest month of the year. my mates built silvia lost a about 10hp every run due to heat soak at a dyno comp on a hot day.
Edited by mad082
And if you notice a throttle difference with an extra bend or two, i'll hand you a medal :(
Cause you wont notice it at all IMO.
Im with you on this one. As long as the piping is kinda right in the first place...i dont think there will be any noticable difference.
...but the overall idea is to have the radiator sitting on a 45 degree angle and your intercooler sitting on a 45 degree angle, the overall the advantage is that the pipes are shorter, and neither your intercooler or radiator are getting less air flow. The disadvantage to this setup is heat soak.
But they do get less airflow, the air has to either go up through the intercooler or down thru the radiator. It does mean though that the lsioghtly heated air that has passed through the intercoole risnt used to cool the radiator. But thats not a biggy anyway as the radiator can be sized accordingly.
The main reasons in racing are that you get better weight distribution as ther heavy (full of coolant) radiator sits lower in the car. It also helps in race cars as when 'rubbing is racing", well with the IC behind the raditor support panel it is not going to be punctured meaning loss of power.
Frankly im surprised that ppl who are concerned about this do not grab an STI cooler. Weld some sheet and baffles over it. Top mount the thing and run a water to air intercooler. You get stable inlet temps. With water you get the chance to actually lower the inlet temps below ambient (ICE BOX etc) which you can do when using ambient air as a coolign medium.
Depending if you clock your turbo housing correctly, you basically end up with a single bend and less then 5" of cooler piping. That woudl be a dramatic enough a change to actually made noticable differences when driving the car.
There are of course disadvantages, being the weight of pumps, water and the reservoir. Introducing a pump that can fail, and puts an addiional load on your electrics...but i think a top mount water to air cooler is about ideal for a road car that gets raced from time to time.
...oh and ithat engne bay pic a 350Z??? Why on earth would you rip out a gem of an engine to fit an SR20??? cRaZy Japs :)
Many valid points.
P.S the engine bay is my 4 door R32 (dedicated drift car), I wish it were a 350z.
EDIT: you obviously mean the other engine bay.. my bad :(
Greg
Edited by EXAUNV
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
