sounds like from snowy's report that a 10.something is certainly attainable for it. 10.04 maybe not, but it's not really the point. it's not a drag car. just a very capable, and desirable road car.
  • Replies 117
hmmm... was this a GTR that was sent back to Nismo to get all the Z-Tune parts put on, then the car was sent back out?
because i've heard there is one of the 20-22 here, but it's never been tracked. Meaning, there are 2 Z-Tunes. Both in melbourne, 1 is one of the original Nismo factory made ones, 1 is a fully kitted out one...
I have no idea who you are talking to but they are feading you some inacurate info. there were only 20 Nismo GTR Z-tune made. They were made to commemerate nismo's 20th anniversary, not their 22nd aniversary, or their 23rd. 20th. and as such 20 is it. no more, no less.
There is only 1 in Australia. Made by nismo just like the other 19 were. a nissan GTR with a body kit is not 'a fully kitted out Z-tune'. If it doesn't have a plaque on it that says Nismo GTR Z-tune XX/20 then it's not a Z-tune. pretty simple.
Yeh Giants car is a little lighter then most R32s (i think) and has the close ratio box and is makign more power then the Z-Tune. With 320swkws i woul dbe very surprised if it ran a lot 10. Perhaps a 10.99999 :(
Unless of course the thing has another 9psi they can wind into it and make a lot more power
beer baron, i said 20-22 because i couldn't remember exactly.
There is nothing stopping you from "making" a Mines GTR, and the same for a Z-Tune, you can make one from your existing GTR. And, as far as i knew, this was the ONLY way to bring one out to australia.
Get a normal GTR here, compliance. Ship back to japan. Get Nismo treatment. Bring back to australia.
This, technically, is NOT one of the 20 built.
Granted the guy who told me that his clients car, that's a Z-Tune, which is not tracked, doesn't know a lot about jap imports. Owner's name was 'John'.
i dunno... just something i heard. Because if the only way to bring one here, is to do the whole back and forth thing.. then we still don't have one of the ORIGINAL 20?? i could be getting confused somewhere along the line though...
I hear what you are saying...and you could build your own Mines R34 but you cant build a Z-Tune. Nismo have the car and owner details of each car and if you are trying to buy parts then you have to own one of the 20 cars to get parts. So unless you go and guess the turbo specs, make the panels, get Brembo to do a special run of the calipers for you, copy all the coolers and installation etc, forge the build plate etc etc then you may be able to have a look a like. But since Nismo wont sell you any of the parts you cant build one
right o. I was mistaken then. I thought Nismo were building them from scratch, as oppose to sourcing mint condition, 2nd hand ones.
well, off to tell my car detailer he's quite wrong :laugh: sorry for the confusion
well, apparently this owner also has about 10 other AMAZING cars. ferrari's, 2 x GT3's... etc... got good tastes :miner:
Im in japan at the moment and we happened to pass the omori factory and had to pay a visit of course...
We walked into the garage entrance and first we saw an nismo r32 gtr s tune, next to which was an r33 gtr 400R, next to which was an r34 gtr ztune. We got to sit in it! Under the bonnet was the plate which showed it as being no. 1 of 20. This car by far is my dream car but its pretty much impossible to aquire even if I was loaded, but to see it and sit in it was an awesome experience and the keys were sitting in the ignition too :( haha, but they wouldnt start it!
well, apparently this owner also has about 10 other AMAZING cars. ferrari's, 2 x GT3's... etc... got good tastes :)
They couldn't build them from scratch as there was no more R34's being produced :laugh:
  • 2 months later...
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
    • I leant out the window recently and took a picture of this new WRX. It looked real damn fine in person. It's faster around a track (stock) than a (stock) GR Yaris. It's much more practical despite being heavier. It's significantly cheaper. This gen tunes really well, much better than others. .... I think they're probably a lot better than people expect.
