  • Replies 117
And don't forget guys, this car does a 10.04 sec 1/4 mile according to the owner. It was published in this month's Autosalon magazine, full write up on the car....
Was at Dutton Rally at Sandown and overheard the owner claiming it had done a 10.04 sec 1/4 mile in Japan.... :D
Is it just me or does anybody else find that hard to believe???
500ps + 1500kg = 10.04??? :D
Oh, and why didn't they say what mph it reached??
Still, I'd buy one..... :laugh:
Was at Dutton Rally at Sandown and overheard the owner claiming it had done a 10.04 sec 1/4 mile in Japan.... :nyaanyaa:
500ps + 1500kg = 10.04??? :dry:
Still, I'd buy one..... :sleep:
Everyone talks it up... just some go further than others...
It has a lot more than 500ps :/
Really?? Has it been modified beyond Nismo Z-Tune specs?? Or is Nismo underrating the power??
Here's the specs according to Nismo: http://www.nismo.co.jp/Z-tune/data_e/6.html
They also claim it weighs 1600kg, I thought it would have been 1500kg with all the carbon fibre.
Then again all the diff/trans coolers would add weight...
So blacksx, how much power has it got?? I'm curious... :)
Was at Dutton Rally at Sandown and overheard the owner claiming it had done a 10.04 sec 1/4 mile in Japan.... ;)
500ps + 1500kg = 10.04??? :)
Still, I'd buy one..... :(
I don't find it hard to believe, the data was recorded on Nissan's own test course so I'd be happy to believe it were true.
If it came 4th, who came 3rd, 2nd, and 1st?
P.S. dream car there...
Team Outright
1. Mitsubishi Lancer EVO VI
2. Whiteline EVO VIII
3. Mitsubishi EVO 3
The Z Tune actually scored enough points to place 2nd outright however it was docked points by the officials for some "circular antics" in the pits/carpark
The proto version would run 10,s but the one;s they sold would no way go 10.02.
In plenty of best motoring vids the Proto version is way faster/quicker and looks like a 10 sec car but in videos with the street version the car no where near moves, revs or sounds quick enough for a 10, It was struggling to catch a new corvette down tsukuba and didnt catch it not to metion the S205 Sti that was in front of them both.
See for yourselfs.
GTR R34 Z -Tune Proto vid at Nurburgring--
http://www.youtube.com/watch?v=735zkR7xTgw
GTR R34 Z-Tune 500ps production model-
http://www.youtube.com/watch?v=-emo2QIMmeY
There is another video of the Proto at Nismo festival Fisco and it came 3rd the vid isnt on Youtube anymore.
1st was ATTKD BNR34 GAIAX
2nd Mines BNR34
3rd Z-tune Proto
4th MCR BCNR33
The proto had closer to 800ps no cat converter and more agressive tune that would go 10.02, the production one would of never kept up with the mines GTR
Edited by nismo 400 R N1
See for yourselfs.
2nd Mines BNR34
3rd Z-tune Proto
4th MCR BCNR33
Thought so, the specs just don't add up...
The proto sounds like it had no restrictions like the production model has...
Thanks for the info!!!!
I can't say for sure if this Z-Tune could run a flat 10 or not.
However what I can say is that in the Dutton Rally Vic this year the Z-Tune on the Airport run ran a best time of 15.46s.
It should be noted that Mark Berry's best time for that event is 15.76s and Mark has run a 10.4s 1/4 mile. So the Z Tunes drag time was under Marks time and Marks 10.4s was done on R Comps.
Having competed against the car there is no question it's a decent bit of kit.
