hey guys just selling my RB26dett
the engine includes CP pistons , cryo rods and crank , arp head stud kit , n1 oil pump , new water pump , cametic head gasket, jun cam gears , port and polished head , acid dipped block, bottom end done by bryants engineering and head done by barkleys , also comes with rb26 gear box , the turbo is a GT40 1.06 rear and a .50 front the front housing is polished , with high mount manifold , genuwine tial waste gate with screamer, comes with twin R33 air folw meters .custom pods to fit , dump pipe to suit 3 inch , 650 injectors , sard fuel reg, power fc with hand contoller gates timing belt , gates radiator houses , ford blue tapper covers , poilshed plenum , 5000 k old 5 puck brass button 3800 foot pound nismo clutch all braded lines all piping is polished, engined is tuned by mark at godzilla motorsports , currently making 507hp the all 4 wheels only only 21 pound plenty more in it , the motor is still in car so you can see how it is running , the motor is healthy as ever only done 5000k's since rebuild never drivin on 507 hp only tuned as i never got around to getting a boost controller only ran 16 pound making 430 at the wheels awsome motor for GTst or what ever the rebuild cost me 9000 selling everyting for 8500 ono , 10 sec motor im in brisbane will send any where prefer brisbane , matt 0422883933 thanks got dyno sheets dont really wanna seperate the things the engine is coming out of a R32 cheers if want photos ask pm
    • Yes to both! Yes to standard ECU and tune, but exhaust is aftermarket. Unsure on brand. Actually have it sitting in at my desk haha! I have to set it up on my laptop but this is a great next step, will do. So I generally try to shift before 4.5K RPM most times. I largely don't do a lot of high-rev driving, but I will take it up to red 1-2x a week max, as I know the occasional "Italian tune-up" is good for these cars.  Oh wow, is this way better than what I'm getting. Does this mean there's a good chance I have an issue?   Thanks for all the info so far guys.
    • Old Son, did you re-use the Holden ABS in the new shell or try a different module?
    • Yeah, nah. I had the actuator rod off it today. The arm will not move at all. Neither out, nor in. Yeah, you'd think so, but I've been thinking about that. Even when the actuator rod fell all the way off at the beginning of this saga, it would build more boost and faster in lower gears than it would in higher gears, and you'd think that that was the opposite of what should happen. But I strongly suspect that there is a thing with the gearing getting the revs to rise faster, that there must be some transient effect with the gas flow rate rising quickly, that you don't get with the more steady state case of the higher gears. Keep in mind - the gate is not shut in either of my weirdnesses. So things are not "normal". We normally think about a turbo spooling up (below the wastegate target) with the gate shut. I have all sorts of mental models running now where the gate is a little bit open, and having it stuck open allowing gas out while it should be going through the turbine has all sorts of weird effects (in these mental models). I'm thinking in the higher gears, the ex mani pressure builds to the point where enough gases spill out the wastegate to just prevent the pressure rising much more at all, or just creeping up, all the whole the revs are increasing and getting closer to the point where a gear shift becomes necessary.
    • Is it possibly wastegate actuator itself is sticking, or even the rod to flapper? Otherwise I reckon things are getting a bit rusty/worn   Also odd it won't boost in 3rd to 5th, but will in 1st, I'd expect the other way around with it slightly open as there's more time on your way to redline for it to spin up
