Yeh hi since ive turbo'd my engine rb25de i put a drift oil breather on as shown in the picture!
the as u can see the blue'ish filter there use to be a hose leading the the stock airfilter piping...
since i turbo'd my engine i had nothing to put there other then this filter.
when i give my car a bit it seems pressure is building up and forcing oil out of the filter and yeh needs to be fixed asap. can anyone tell me what i can do to fix this problem?
Thanks heaps people!
Edited by Stealthynsa
https://www.sau.com.au/forums/topic/131580-oil-problem-since-turbod/
oil coming out of that line will happen no matter what you do.
only thing you can do to stop it from going around your engine bay is to stick fit an oil catch can.
do it ASAP. the oil around your exhaust manifold coult start a fire!
its not coming from the turbo oil line... its coming from the top of the engine where the filter is...
and oil catch can? what would this do to help me, i tried pluging it up once but then the pressure built up
and spat out of my dip stick...
i didnt say anything about a turbo line.
the place where you fit the breather is meant for a pipe heading back into the intake.
air comes out of there and sometimes oil will come through your rings. this is called blow by.
do a search on catch can and you'll find something.
so if i put this catch can on there wont it also over flow?
or does it drain back into the engine? what happens if this builds up with pressure?
btw thanks for ur help dude
yeah it will fill up eventually, but at least it wont spill onto your motor.
im more worried about your dip stick blowing out. have you gotten a compression test done? this is usually a sign of worn or even damaged pistons/rings. get it checked out asap.
the catch can doesnt fill up with pressure, the air vents back out to either your intake or atmo.
how much is a compression test/ where would i go... and what do they do to test it, am i able to test it myself?
whats a atmo?
there is a fair bit of oil that comes out... it never happened untill turbo'd it.
and also when i give it a bit of a rev burnt smoke comes out of the filter would that be normal im guessing its burnt oil?
The oil wont overflow, the blow by will then be caught inside the catchcan instead of spraying all over the place inside your engine bay, As security said its actually meant for a pipe to go back into the intake
so by u saying a pipe goin back to my intake... u mean the 2.5" piping to the throttle body?
you could do it yourself, but it'll be hard to crank your motor while reading compression, just drop it off at a mechanic and ask for a compression test and a leak-down test. it shouldnt cost too much, probably the same amount as buying a compression tester.
atmo = atmosphere.
atmo = atmosphere.
where is the atmo?
thats your inlet pipe.
intake is your air filter pipe. so it needs to lead to your turbo.
a catch can will seperate the oil from the air before it hits your engine though. thats its purpose.
ok now u have lost me sorry about this...
um i put 1 of the tubes of the catch can onto the part where its leaking ontop of the engine.
and ur saying i put the other tubing into the atmo or the intake? if i put it into the intake wont it go back throung somewhere its not suppose to?
read:
http://www.skylinesaustralia.com/forums/in...%20can&st=0
this is a goodie:
http://www.skylinesaustralia.com/forums/in...20can&st=20
on the side of ur engine u have a oil return line from a step down at the fron of the rocket cover down the the bottom of i the engine... i T peice my turbo's oil return line in there... would this be why ther oil is coming up and spurting out? im saying would the oil+pressure from the turbo's oil return go back up through the oil return from the head and therefore come out my airfilter?
if you've T'd it into a pipe you KNOW to be an oil return pipe it shouldnt be a problem.
i know its an oil return from the head but what im saying since there is pressure coming from the turbo oil return would it head back up the oil return from the head causing the head to overflow and rid the oil out of my air filter?
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
