r33bob Posted August 24, 2006 Share Posted August 24, 2006 hey my r33 gtst after it has warmed up, starts to backfire when you stop accelerating would this be using like much more fuel and or what would be casuing it to do this? Link to comment https://www.sau.com.au/forums/topic/131615-back-firing/ Share on other sites More sharing options...
mad082 Posted August 25, 2006 Share Posted August 25, 2006 do you have an atmo bov? and yes it would be using more fuel, but not very much. Link to comment https://www.sau.com.au/forums/topic/131615-back-firing/#findComment-2438691 Share on other sites More sharing options...
r33bob Posted August 25, 2006 Author Share Posted August 25, 2006 nah its all standard except for the exhaust on it.... do u reckon it could be the o2 sensor? Link to comment https://www.sau.com.au/forums/topic/131615-back-firing/#findComment-2440143 Share on other sites More sharing options...
mad082 Posted August 26, 2006 Share Posted August 26, 2006 could be o2 sensor, or it could be an exhaust leak. generally if there is an exhaust leak (more than likely just after the turbo) it sucks ait back in and backfires. my mates old EB falcon had cracked headers and it would shoot flames out the back when he backed off until he got them fixed...... but his cat was empty too. Link to comment https://www.sau.com.au/forums/topic/131615-back-firing/#findComment-2440910 Share on other sites More sharing options...
r33rb26ett Posted August 26, 2006 Share Posted August 26, 2006 its to do with nissans rich as air/fuel ratios. once you back off it dumps the excess fuel in to the exhaust and BANG!. an aftermarket computer like an apexi power fc will fix most of this up as its tuned to run leaner Link to comment https://www.sau.com.au/forums/topic/131615-back-firing/#findComment-2440936 Share on other sites More sharing options...
mad082 Posted August 27, 2006 Share Posted August 27, 2006 thats not very accurate. if you are running rich and your spark plugs are working fine then it should still burn all the fuel dumped in. try putting new plugs in and see what that does. mine used to pop, and stall ocassionally on decel after full throttle high rpm runs. put some new plugs in and it went away. Link to comment https://www.sau.com.au/forums/topic/131615-back-firing/#findComment-2442482 Share on other sites More sharing options...
r33bob Posted August 28, 2006 Author Share Posted August 28, 2006 thanks when i get some spare cash and time i will try it Link to comment https://www.sau.com.au/forums/topic/131615-back-firing/#findComment-2445408 Share on other sites More sharing options...
