he guys , latley ive been debating on wether to rebuild my rb20 or go the rb25 conversion. its been hard trying to find an rb25 with all the other things like gearboxes and turbos, all that shit. anywaz ive been told to rebuild the 20 and get the head flowed ect. ive got around 8 grand to play with and im in perth. wats the go with rebuilding rb20's . i want the car for the street daily driver and for abit of fun on the track aswell. any info of any kind would be appriciated
simon :)
https://www.sau.com.au/forums/topic/131626-rebuilding-a-rb20/
stock bottom end is good for about 400hp but to be safe I would be changing to forged pistons. ROSS make custom pistons for the RB20DET and they will set you back around $1500 including rings.
I would definately consider the porting you mentioned as every little bit helps with the 20's. You should also have the rods resized to ensure correct fitment and lose the chances of spinning a bearing easily. 8 g's is not really going to satisfy the budget once you get right into it. You should do cams, injectors, AFM upgrades while you are at it and make sure you have a clutch that will do the job. The RB20 gearbox will not last long at 200rwkw so you should also budget for an RB25DET box and fit it at the same time.
8k you have to play with?
RB25 conversion mate.
If you had a larger turbo etc etc already i'd say stick with the RB20.
But its pretty standard, so any cash you spend it going to better you regardless.
IMO Rebuilding the 20 and then doing a turbo will cost you more than an RB25 conversion, keeping the stock turbo and getting a PowerFC or similar.
RB20 box will be fine with a stock RB25 without a drama, even upto (give or take) 250rwkw in my expirience.
And that will be under 8k quite easily without having to do the gearbox. Which could even allow you to get a larger turbo for the RB25 + injectors/AFM 6-12 months down the track if you save a tad more :)
If you run good gearbox fluid, a sensible clutch and dont drive like you belong in a padded room then an RB20 box is fine up to 240-250rwks. It will go bang sooner or later, but my old thing is still tracking well after 180,000kms so its not unheard of. Some die straight after a power hike, so if it doesnt go in the first month or so you may be able to cheat death.
The big question is what are you wanting to do with the car and what can you so yourself?
8k is a lot of money. If your RB20 is happy at the moment, then i would grab a 2530, remapped ECU and be on your way for around $2500. Spend the rest of your money on big nights out and driving the car at the track with a good 210-220rwkws.
If you really want to spend the 8k, then its a lot of money if you can do things yourself, not a lot if your paying a workshop. You would be looking at around 3.5k for a mechanic to do the swap for you. You will need a Pfc and you will make around 200rwkws with a turbo that may go bag at any time.
So say 3.5k for work, 3k for engine and gearbox and driveshaft...it leaves you with a bit of money to play witha high flow turbo etc that will net you around 240rwkws.
RB25 is a good building block, but its a lot of money for that bit of extra low end grunt. RB20, well i wouldnt personally even crack the motor. Just throw a big turbo on it and go have a ball driving it. Be careful even with cams. I have ummed and arred so often with cams, but am concerned about losing even more grunt under 3,500rpm for that little bit of extra top end. I want cams more for the low to mid, and ppl have raised concern over me losing low end so havent bothered.
Which ever way you go, plan it well as you can, and get as many fixed price quotes as possible from ppl that have done it before and know what they are on about. You can do a turbo and ecu upgrade in 2 days. I can see an RB25 transplant taking 2 weeks.
    • The car remains in paint jail. I am now pretty convinced that the whole "RB25 Airboxes are kinda limiting to ~300kw" could be a thing. Also saw a good video from Engine Masters: (Sorry for FB link) (https://www.facebook.com/watch/?ref=search&v=761771519471924&external_log_id=c10bcbb6-2c39-4ff3-9240-287e9921fde6&q=Cold Air Considerations) Where they tested Pod Filter sizes and kept adding bends to a LS3 on an Engine Dyno to find if bends caused power loss. It's a good video worth watching - They did lose ~25hp from making an intake which had 3x90's and a 120 degree. They only lost maybe 1hp with a basic 90. I feel that by sealing up my airbox I have: 1) Created the same restriction a stock airbox would have. 2) Created a very convoluted set of intake 'pipes' by forcing all the air through the ducts. So I am pretty confident I'll be going full circle and have a huge hot air intake pod and actually see a benefit. The air does *not* stay hot once it gets flowing, aided by the ducts, and the pod can then pull air from anywhere. All the posts of yore talk about the stock airbox costing 10-15kw at 300kw+ but you know what? I f**king would very much like that 10-15kw and I remember my own pod filter in engine bay experiences. Turns out the GTT Reo and Headlight brackets really don't allow you to mount GTR items, no matter what the internet says. Various brackets have had to be made up to actually make it fit right for the front bar. Also some idiot mounted a 3L Accusump right where the bumper wants to go, so that has had to be 'relocated' To where, I am still not sure, but it's supposedly mounted in the pictures and I can't see it.
    • Sounds like the oil pressure light is wired into the oil temp sensor... As it warms up, resistance on temp sensor reduces, hence more current can flow and the dash light gets brighter.
    • Got the front subframe and suspension in.
    • If it's cold in summer, then no issue. If it's cutting out every few seconds and you're not reaching your target temp, then there's an issue. One could be the pressure switch and the other issue could be the temp probe inside the evaporator.
