Hks Or Jun Cam Gears? (scratch That I Ordered Tomei's)
  mitchy_ said:
id say JUN purely because it sounds better than HKS. :D
i imagine they are both the same duration/lift/etc?
I like the shcuzsched 'J' sound, its awesome....also they are a grey/black colour and would go with the resr of my Nismo gear. Found out that Nismo don't do cam gears :D
Yeah, they'd both be for the RB26 motor. Prices from Greenline.
check speedworks website they do JUN here in perth
Speedworks Motorsport
4 Carbon Ct
Osborne Park , WA 6017
Phone: (08) 9242-8888
Fax: (08) 9244-3888
http://www.speedworks.com.au/main.html
  djr81 said:
Get the Tomei ones. Better than either of the other options.
Really?
I never really like the style of the Tomei ones, but I guess you dont seem them anyway ;)
So they are better than HKS and JUN?!
hks - ANODISED DURALUMIN CENTRE WITH NICKEL PLATED GEAR TEETH - duralium - synthetically made alloy - aluminium with 4.4% copper, 1.5% magnesium and 0.6% manganese. So its probably more flexible strong then strength strong.
tomei - are made from just duralium with no nickel. I am not to sure if this makes it stronger or not but the masses seem like them.
jun - I cannot find any info on these to be able to comment but my bet is duralium and nickel or steel.
Edited by Tofu
  play r 32 said:
sorry if im stealin thread, but what difference does just changing cam and cam gears do to a rb26 ?
I have a Nismo belt to do at the same time and a new radiator and hoses I will do as well. Just getting my car ready for things like internals (maybe) and turbos
  kingscorp said:
JUN are stock Nissan gears modded and are ok but very heavy.
Very heavy? Surley if its a nissan gear with the centre machined out and an alloy centre it would be lighter than stock. (maybe not as light as hks etc)
But id rather pick a "non wearing item" for that kind of money.
We'll see in a few days anyway ;)
If you are thinking about new cams at any stage you can give the adustable pulleys a miss as the Poncams (To use but one example) have different centres to the stock items & you don't get such a gain from playing around with them.
Get a water pump too. You may as well do this at the same time as you will be up to your armpits in it all.
As for the whole steel/aluminium/duralium thing. It doesn't matter that much. What you have is essentially a rubber toothed belt that is running in the cam pulley. It doesn't wear the pulley worth a damn. The only way it can do so is if you are vain/stupid enough to leave the dust cover off it.
The advantage of an aluminium set of pulleys is that they are lighter & take some of the reciprocating mass off the engine & hence make the pulleys job that little bit easier.
The Tomei ones are good because they are from the appropriate grades of aluminium (ie duralium etc) & also have five locating bolts instead of three or four like many others. Lastly, the pretty blue colour matches my eyes & the red my handbag. ;)
Yes, I probably will get the Tomei Poncams in the future. So do the Poncams require specific cam gears that are different to stock items and the gears I am looking at now?
Water pump, I have been contemplating that but I have the radiator to do as well and I have no problem with temps as it is. I might just give that a miss.
