Rb25det Neo Intake Gaskets
S14MARKSR
 Share
i am having to remove my intake plenum so i can get at my injectors for upgrading them. my question is can i reuse the original gasket or would it be better to replace it..the reason i am asking is i am located in the US and these engines are far and i mean far from common and i have no sources here to acqurie new one if needed, also i am in need of a new oil dipstick due to the original one being broken in transit. also if anyone has any ideas as to upgrading injectors feel free to chime in please..so far i have only seen one (SARD) has a full set..wow they are high though
please help :(
Edited by S14MARKSR
If it is the same as the rb25 series 1 & 2 plenum gasket you will be able to re-use it. its got big rubber o rings. it will be O.K.
please help :D
As for injectors you're in the lucky country, the aftermarket 350Z/G35 injectors will fit straight in!!!
Check out www.350Zfrenzy.com and www.g35frenzy.com most people there could help you out with locating some good injectors.
oh wow...that is incredible...thank you so much..i do have one more question...the stock turbo had about of qt of oil in it..lol yeah a qt, and im yanking that one off and i have a garrett 60-1 that came off my built SR i had before i went to this engine...with upgrading the injectors and using a power FC you think i will be ok on the stock head gasket for a little bit. i dont mind changing it but i have to say i am running out of money fast going to this style of engine..lol...but i must say i am still happy with my decision due to the fact these engines are very rare over here..
thanks for the info again...i just scored me some 650's from a G35 buddy of mine for 200.00 bucks..best deal i have gotten so far...
No fair, can you get me some for that price?
Also, regarding the the gasket. They are not the same as the R33 ones however you can reuse them if you are careful on removal. They can get stuck on the top part in one area and the bottom part in another area then break with you lift the top part off.
That said, they don't stick like with gasket goo so are easy to separate as long as you are careful.
  • 17 years later...
 Share
    • Gone into r34 gt4 non turbo model
    • Sorry to sound thick....but what does the "faceplate" have to do with adjusting the odometer? Surely the odo stays put and you change the fascia. Surely they are not the same thing.
    • I know its been 13 years since this topic, but it came up when i was searching to fix my problem so thought i would add my 2cents in and how i fixed my issue.  my r33 had air coming out off all the vents except the center one. i went straight down the rabbit hole expecting it to be a mechanical issue, pulled the dash apart tracing lines, checking linkages etc. it turned out the very fine fly screen mesh behind the center vent was actually VERY blocked so when i had the air on face the air would take the path of least resistance and come out the 2 side vents but allow nothing out the center vent. a quick clean fixed the issue. once the mesh is clean you can see the air direction flaps moving inside through the mesh.
    • Glad that worked out for you. I think my Joyeauto one is coming this week but I won't get to install it til closer to end of October. Will update when I get around to it. Just standard CP and nothing else. Hopefully the cameras all work without needing to get out of CP and get back in as they advertised. My other worry is sound quality. Fingers crossed!
    • Yeah, it is possible. But like many related things (ie, alternators), it's getting harder to find anyone who does and will, given the change to just throwing shit away and replacing with new cheap shit from Chinese factories. If you want to pursue the option of rebuilding, you'll have to dig up an auto A/C specialist or three to find out whether they still do.
