As the subject states, i'd be interested in hearing from anyone using any form of upgraded turbo on their RB20.
I have heard so much positives and negatives about Hi-Flowing the standard turbo, fitting a VG30 and fitting a RB25 turbo that i am confused.
Can people who have actually done anything (even aftermarket turbos) please buy in to this argument and help me out.
I'd be very interested in some comments and results.
  • Replies 43
Mr RB20
I am also interested in the same mods..... i ve herd that the VG30 turbo is a excelent and cheap upgrage for the RB20. but dont expect more than 190-200Kw @wheels. however rebuilding the VG30 (with a steel exhaust wheel) plus hi flow can get a little laggy, and will probly only make 200 -220 Kw @wheels... exactly how laggy i dont know ive spoken 2 a few performance places and know one can give me a straight answer.... does any one have any other info???
pm either inark or meggala, they've both done some work on their RB20DET's. meggala changed his RB20DE to a DET and inark is currently putting a VG30 turbo on i think.
Mr Rb20
I'd stay away from high flows of the stock turbo, unless you only want another 15-20rwkw. A series one R33 turbo will give you a bit of a increase, but you can only run 14psi due to the turbine wheel being ceramic.
After a lot of thinking i ended up getting a HKS 2510 turbo second hand. My goal was to have 200rwkw, with as little boost as possible, and still have almost stock drivability, and the 2510 fits the bill pretty well.
With my current setup - stock engine, tube and fin front mount cooler, Bosch motorsport pump and re-mapped stock computer, it made 198rwkw with 1bar boost on a warm summers day. The best part is that it drives very close to stock, just has a heap more top end.
The best part is that the turbo is still running lowish boost (for a HKS turbo) and has the ability to run 1.5 bar and make around 220-230rwkw with a revised fuel system.
Bolt on HKS turbos are awesome in my opinion, I'd recommend one if you want to upgrade
Chris
Thanks for all the replies.
I'm thinking now of upping the boost on the standard turbo to 16psi.
I have a front mount and exhaust so i hope this will be alright.
I am trying to eliminate some lag.
Chris - where does the boost start to kick in on the HKS and when does it hit full boost and till what revs ??
HKS bolt-on seems like a good idea although the VG30 is still very tempting.
Anyone in SYdney that can show me their car with an upgraded turbo ??
Starts to boost at 2100, full boost at 3800 -4000, keeps going until rev limiter of 8000rpm
HKS stuff is awesome for higher boost as well. I can't think of another turbo that will make 230rwkw and still drive like a stocker down low
Chris - The HKS sounds like a damn nice turbo, wanna sell ??
Lowlux - how does the car drive with the VG30 ?? ie when does boost start to kick in, when is it on full boost and when does it start to die off ??
How much of a difference is there to the standard turbo ??
High flowing a stock turbo should include a new stainless steel spindle and intake/exhaust wheels.
You should be looking at well over 20psi safely on a flowed stock.
The translates to much more than the 15-20rwkw you speak of...
This also does not take into account larger trim wheels you can install.
T.
Nah, its not for sale. You should be able to pick one up for around $1500, but they are hard to find. Maybe even look at a HKS 2530,2540,2535. These are a bit bigger and make more power but have more lag
tlai909 - I don't doubt that high flows can make power, but the ones I have seen have hardly made 20rwkw more at higher boost. For what people I know have paid for these they haven't got a good gain for the money spent.
I have seen a couple of rb25 high flows that have made good power though, but its hard to compare them with a rb20 high flow
I think it also comes down to cost.
I got some OUTRAGEOUS figures to flow and refurb a stock turbo (up to $2,500!!!).
In this case a HKS2540 is your friend :rolleyes:
On the plus side a flow stock obviously is easy on install, uses the same pipes and does not alert the police OR insurance :D
T.
I am currently running an rb 25 turbo andhave run a vg 30 turbo on my car the rb 25 turbo doesnt make as much paower as the cg 30 but come in earlier my car has run a 14 flat @ 98 mph the car made 148 rwkw and could of made more as the tune was conservative from the sounds of it the hks turbos are the way to go. I have driven a car with a hi flowed vg 30 turbo it was awsome (dr_drifts old car thecar ran a 108 mph at the drags but had to much wheel spinfor a great time that or the hiflow rb25 turbo is the next option I"m considering at the moment.
as a guide you really dont want the exhaust wheel much larger than 54 mm on
an rb 20 as this makes the car way to laggy ie full boost over 5 k rpm
a cremapped ecu makes a world of difference as well we found gains of 15-20 rwkw at a recent dyno day
meggala
Hi guys, on our RB20DET we have tried;
*standard RB20 turbo (spat the ceramic turbine at 10 psi)
*standard VG30 turbo (in fact 3 of them, 'till we found a reasonable one, but even it spat the dummy shortly after)
*standard RB25 turbo (good for 20 rwkw more than RB20 turbo at the same boost)
*hi flowed RB25 turbo (good for 350 bhp = 210 rwkw at 1.3 bar)
*HKS 2540 (also good for 210 rwkw at 1.5 bar, but way more lag than the RB25 hi flow)
So my recommendation would be hi flowed RB25 turbo, as the other guys have said, it fits straight on, no fabrication required, looks like a standard turbo (has Nissan written on it). When you get a turbo hi flowed you basically end up getting a brand new turbo back as all of the bits that wear are replaced plus the rotating bits are micro balanced. We use GCG turbos for our hi flows as they listen to what the customer wants and then make up a turbo to suite their requirements.
Plus one of our RB25 hi flowed turbo's has just had an upgrade to 55 lbs per minute of airflow at 1.4 bar (should be good for a bit more than 550 bhp), way cheaper than buying another turbo.
Hope that helps.
    • I don't like "actual computers" for in car use. They take time to boot up, have OS annoyances, and so on. Arduinos etc are ready to go a few seconds after power on, don't mind being agressively powere cycled, because everything is non-volatile, don't mind being shaken and stirred.
    • As Fred would tell us, it's all about interpreting the rules. It's not a water sprayer, it's a water mister... But everything else you've said, 100%! Even a raspberry Pi would be great, use HDMI out for a display, and add a raspberry Pi CANBus hat to read values out from the ECU.
    • Being a race car, and being in the era of the Arduino, one would think it would take little effort to build a controller to do the spraying based on a real physical measurment. Waaaaay back in the dim dark AS days, JE "designed" (as in, he had help) a microcontroller based intercooler spray system. It watched the difference between a temp sensor stuck on the core and one in the free air in front of the cooler, and if the temperature difference exceeded a (settable) threshold, it would activate the sprays. Thus, it only ran water when there was an actual need for water. If you stop to think about the actual physical things that are going on in that stack of coolers, there's probably at least a couple of triggering conditions one could come up with, and one could probably even run one pump with more than one solenoid valve, to allow water to be placed where it is needed, or at all points at once (if it is needed at all points). We're in the age of science baby. But.... I suspect that intercooler water sprays are on the forbidden list in most circuit classes, no? So only good for Targa type stuff?
    • I'll just leave this with, holy shit, those cars at work are awesome, and this will look wicked!
    • Could you modify this duct so instead it pushes the extra air through the radiator too and not down and out? For temps, I know it's not the greatest idea, but as a bit of a last resort, you could use a very intermittent misting spray onto the front of the coolers/rad. You don't want to be soaking them such that water is dripping off, but a small most on/off so that the water evaporates. That point of it constantly evaporating, rather than being soaked in water, will pull a LOT of heat out of the cooler. I'm literally thinking just the little mist sprayers for a garden from Bunnings. Being in a low humidity climate it will help even more! The other trick if you want to be ghetto is some shade cloth hung in the opening, and keep it wet. Pretty much now it's acting like an evap cooler on a house, but cooling the air you need to use to cool the radiator...   On a topic to think about too though, when air enters through the bumper, is it all nicely ducted from the edges of that opening back at a nice angle, or is it like most cars, and the edge of the opening just stops, and suddenly it's wayyy wider behind that? If it does the later, get it shrouded out at nice angles. When that opening changes too rapidly, it can actually cause a high pressure zone between the front bar and radiator, and limit air flow into that area, which means less air for cooling, as it effectively stalls the air, AND adds to drag...
