Thanks Luke.
I have a Veilside chip in my car so i am wondering if they will adapt to the R33 turbo ??
How about injectors and fuel pump ?? Have they stood up to the task or have you changed them ??
What about adding a fuel pressure regulator ??
Also, what sort of difference is there between driving with this turbo and your standard turbo ?? ie does boost come on earlier, harder, longer etc ??
In other words, how does it drive ??
Thanks
  • Replies 43
I would definately get your AF ratios checked on a dyno with the Veilside chip. It is obviously going to be tuned more aggresively than the standard chip, ie more advance and probably leaner mixtures. Having said that, the difference in airflow between the standard turbo and the R33 would not be huge, so you may get away with the ecu setup that you have. Better safe than sorry anyway.
Your injectors should still be fine with the mods that you have listed. Your fuel pump should also be able to keep up as long as it is in good condition, but again this is something that you should probably check. An adjustable fuel pressure reg is a bit of a band aid solution in my opinion, and should not be needed if it is tuned correctly. The only time they are useful is when your injectors start to run out of flow, which I don't think will be an issue for you yet. Other people on here will have a much better idea on this than I do.
As for how it drives, with 10psi boost it feels pretty soft through the mid range, coming on boost a little bit later than the stock turbo, and then starts to go better than stock when it hits 5000rpm. At 14 psi it is much better, pulling much harder than the stock turbo from about 4500 all the way to redline. It is definately worth doing.
Hi Mr Rb20, we have not found any difference between the compressors, plastic or not. The failures have all been the ceramic turbine. The R34 killed a turbine at 12 psi and the R33's did the same.
When I have a car with a ceramic turbine in it I stay under 10 psi, I just don't like the consequences. As fast as I can I upgrade it to a steel turbine, even if it is exactly the same size as the standard ceramic. Hi flowing is of course better but more expensive.
Hope that helps some more.
    • Welcome Jan, It's very likely that you are in over your head. You'll just have to learn to swim hard and fast! These old rust buckets have more ways to bankrupt us than almost any other car. But hopefully there's nothing wrong that ruins the whole show! We can help a fair bit. There's plenty here who've been fixing these things for >25 years. cheers
    • Hi all. First off, thanks for reading my post. So end of last season I put the car away knowing I was leaking at least two fluids. One of them being rear turbo's oil. I went to my car recently that is waiting in a garage to take a peek with my boroscope to try and see if I can narrow down the souce of oil before taking it out of storage. What I found is not so great I think. The rear turbo is (probably) leaking from the oil drain. The hose and it's clamps are probably the original ones, so most likely just worn out or loose. However I spotted a line of rust going straight down from the turbo oil feed, as if water leaked out of there at some point. Also explains the red liquid that was dripping from my front subframe, which I initially thought was power steering. I can even see coolant drops hanging off the side of the oil pan as well. After a quick hit on the web I found a select few discussions about porous engine blocks. My question is if the pics of the turbo oil feed and the left hand side of the block (imgur link below) looks like it could be exactly that to you. Maybe someone in the community has seen it before and knows what it looks like. If it actually is a porously leaking block, has anyone attempted at fixing it with simple methods like putting a sealer in the cooling system and using something like jb weld on the block surface, or will it just leak in 2 weeks again? I could not find any detailed info or pictures on this topic. If I need a new engine, tell me softly. https://imgur.com/a/knVvmZ8
    • Hey all. I'm 23 and from Germany, September last year I bought a mildly modded 1995 GTR Vspec. Looks great and was fun so far, but I already have a list of issues of various severity that I need to take care of, potentially growing longer the closer I look. I just hope I'm not in over my head, I really want to keep the car and work towards it becoming great. I hope y'all will help me out in getting there, I am positive I will need help sooner rather than later to figure out how to proceed. greetings, some pics of the car I posted to imgur. https://imgur.com/a/StKkabz
    • Would be interesting what the price would be without the barracuda wheels. Looks like he dropped it down to 40k. Maybe his mate wasn't correct about the 50k evaluation. Has always been a dream of mine to own an auto 33. Looks like I'll have to keep saving my pocket money or ask mum for more pocket money.
    • Thinking about importing a stagea as a family car since i’m getting married this year, thoughts? Me and my fiance both like stageas, but don’t have any experience with them
